Re: Design nearly done - construction started... December 16, 2013 02:44PM |
Re: Design nearly done - construction started... December 16, 2013 03:08PM |
Re: Design nearly done - construction started... December 16, 2013 03:22PM |
Re: Design nearly done - construction started... December 16, 2013 04:42PM |
Re: Design nearly done - construction started... December 16, 2013 05:31PM |
Re: Design nearly done - construction started... December 16, 2013 09:15PM |
Re: Design nearly done - construction started... December 16, 2013 09:24PM |
Re: Design nearly done - construction started... December 17, 2013 03:49PM |
Re: Design nearly done - construction started... December 17, 2013 04:37PM |
Re: Design nearly done - construction started... December 17, 2013 05:22PM |
Probably some kind of switching system, everything's based on having all of the extruders plugged into EXT0 and then run through some sort of multiplexor. But right now, I'm trying to design cold ends. They have to be very small and bullet - proof. If they work out, I may make them available...
Re: Design nearly done - construction started... December 20, 2013 10:17PM |
Re: Design nearly done - construction started... January 04, 2014 10:08AM |
Re: Design nearly done - construction started... January 06, 2014 08:16PM |
Re: Design nearly done - construction started... January 13, 2014 07:48PM |
Re: Design nearly done - construction started... January 14, 2014 04:32PM |
Re: Design nearly done - construction started... January 20, 2014 03:29PM |
Re: Design nearly done - construction started... January 26, 2014 07:55AM |
Re: Design nearly done - construction started... January 26, 2014 01:57PM |
Re: Design nearly done - construction started... February 01, 2014 01:13PM |
Re: Design nearly done - construction started... February 01, 2014 03:59PM |
Re: Design nearly done - construction started... February 08, 2014 02:16AM |
Re: Design nearly done - construction started... February 08, 2014 12:03PM |
Re: Design nearly done - construction started... February 09, 2014 07:42PM |
Re: Design nearly done - construction started... February 09, 2014 09:45PM |
Re: Design nearly done - construction started... February 15, 2014 11:09AM |
Re: Design nearly done - construction started... February 15, 2014 11:29AM |
Re: Design nearly done - construction started... February 15, 2014 03:38PM |
Re: Design nearly done - construction started... February 15, 2014 06:59PM |
I agree with you about holding power, this would be an even bigger issue if I had a heavier mill. The thing I like about the vise I have is the ability to do angles. Yes it is limited there too, but after surfacing it last week, it is more helpful. Anyhow, I do have another shot as promised, this time, the extruders, which barring any final tweaking, are nearly ready to mount on their hub...
Re: Design nearly done - construction started... February 18, 2014 06:44PM |
These were made from mild steel, one of the few items other than the frame not made from aluminum. Once the extruder assembly is done, I will be working on the electronics, along with the housing for same, as I wait for the new linear rods to get here.
Re: Design nearly done - construction started... February 19, 2014 04:45PM |
