Re: Design nearly done - construction started... March 26, 2014 03:30PM |
Re: Design nearly done - construction started... March 26, 2014 03:59PM |
Re: Design nearly done - construction started... March 26, 2014 04:04PM |
Re: Design nearly done - construction started... March 26, 2014 04:22PM |
I would have abut 270 deg of constant contact, but still not be flapping a 7' belt. The more I think about this , the better it starts to sound.
Re: Design nearly done - construction started... March 26, 2014 05:20PM |
Re: Design nearly done - construction started... March 26, 2014 06:23PM |
Re: Design nearly done - construction started... March 26, 2014 07:27PM |
Re: Design nearly done - construction started... March 26, 2014 10:59PM |
. What you might be able to do on your belt tensioners is something I am working on. It is a WIP so I can't verify yet its effectiveness....but, it is the same principal used by the cam chain tensioner on many motorcycles.
Re: Design nearly done - construction started... March 27, 2014 12:33AM |
Re: Design nearly done - construction started... March 27, 2014 11:24AM |
Re: Design nearly done - construction started... March 27, 2014 12:36PM |
Re: Design nearly done - construction started... April 05, 2014 12:03PM |
Re: Design nearly done - construction started... April 06, 2014 06:19PM |
Re: Design nearly done - construction started... April 09, 2014 05:51PM |
arrived today from MEI. It was made to my specs, for a pretty reasonable price. Next I'll need to get the glass and the silicone foam insulation, I will use RTV for assembly. This heater has a thermocouple that will be used for control, via an Auber Instruments PID, and a solid state relay. I will glue in a thermistor to report temps to the Ramps board. The controller is fully programmable, so all of the heater control operations, and all amperage is totally separate from ramps, I do believe this will eliminate a host of problems. This heater runs on mains current, once you get to this size, I think it is the most practical way to do it.
Re: Design nearly done - construction started... May 15, 2014 07:19PM |
Re: Design nearly done - construction started... May 16, 2014 08:02PM |
Re: Design nearly done - construction started... May 25, 2014 04:32PM |
Re: Design nearly done - construction started... May 27, 2014 07:39PM |
Re: Design nearly done - construction started... June 29, 2014 08:13AM |
Re: Design nearly done - construction started... June 30, 2014 09:29AM |
Max I don't know who this guy is but a looks like he just copied and pasted one of my replies I made to you just seems a little weirdQuote
nhathaitrieu6
Maxx you are not that transparent it's just that there's only a few ways to achieve what you want to do. And me being a mechanical type like you obviously I think of the problem and then tried to solve it. If two people think the same way attacking a problem usually come out close to the the same solution
Re: Design nearly done - construction started... July 06, 2014 08:36AM |
Re: Design nearly done - construction started... February 07, 2015 07:34PM |
