Re: Design nearly done - construction started... April 26, 2013 11:44PM |
Re: Design nearly done - construction started... April 27, 2013 09:54PM |
Re: Design nearly done - construction started... April 27, 2013 10:21PM |
Re: Design nearly done - construction started... April 28, 2013 11:05AM |
BTW I am running .35 mm Jhead MKV-b (hotends.com) and 1.75 filiment.
Re: Design nearly done - construction started... April 28, 2013 11:59PM |
Re: Design nearly done - construction started... April 29, 2013 11:57AM |
Re: Design nearly done - construction started... May 01, 2013 08:28PM |
Re: Design nearly done - construction started... May 01, 2013 08:37PM |
Re: Design nearly done - construction started... May 01, 2013 09:00PM |
Seriously though, Beginning this project, I had certain goals, which as I go along i am discovering are not necessarily easily attained. So as I read through this forum and the wiki, and discover what potential issues I am going to encounter, I am trying to evolve my design to take all these things into consideration, which inevitably brings surprise projects into my overall effort. Hopefully at the end, this printer will do all that I want it to.
Re: Design nearly done - construction started... May 05, 2013 01:21PM |
Re: Design nearly done - construction started... May 05, 2013 04:14PM |
Re: Design nearly done - construction started... May 05, 2013 05:17PM |
) and around 60 pieces of aluminum. There is also an upper frame that carries the extruder cold ends and the filament rollers, as well as supporting the upper covers. Things will surely speed up a bit once the frame is done because other than fitting rods, and flat spotting motor shafts, much of this starts to bolt together at that point. The upper frame will bolt to the main frame, because it is not part of the operational geometry, and that allows for final determination of the lengths and angles that will surely affect the success of all those Bowden tubes working together.
Re: Design nearly done - construction started... May 07, 2013 07:18PM |
Re: Design nearly done - construction started... May 07, 2013 07:40PM |
Re: Design nearly done - construction started... May 07, 2013 08:37PM |
Re: Design nearly done - construction started... May 09, 2013 05:12PM |
) switch on my mill whose switch was failing. Different contacts, different altogether.
I even had my friend, an electrician help and it still took us a bit of time, but all's well that ends well, and so to finish up I fitted the mill with a junction box to contain all the power cords.
Re: Design nearly done - construction started... May 10, 2013 10:11AM |
Re: Design nearly done - construction started... May 10, 2013 04:48PM |
Re: Design nearly done - construction started... May 10, 2013 05:07PM |
Re: Design nearly done - construction started... May 11, 2013 02:17AM |
I call this the Land of the Prototypes. When people(I mean clients, not fellow builders) tell me it should only take a moment, and not cost much at all, I tell them - My good man, you are in the Land of the Prototypes now. It only takes a moment to wander in, but it costs a lot more to wander back out!|
Re: Design nearly done - construction started... May 11, 2013 09:10AM |
Re: Design nearly done - construction started... May 11, 2013 11:21AM |
Re: Design nearly done - construction started... May 12, 2013 12:45PM |
, so that's mid week.
Re: Design nearly done - construction started... May 12, 2013 08:55PM |
Re: Design nearly done - construction started... May 19, 2013 08:24PM |
Re: Design nearly done - construction started... May 19, 2013 08:46PM |
Keep it up!
Re: Design nearly done - construction started... May 25, 2013 07:08PM |
Re: Design nearly done - construction started... May 25, 2013 08:17PM |
Re: Design nearly done - construction started... May 25, 2013 08:59PM |
Remaining are the corner legs, which I have elected to make from 3/8" thick 3x3 angle, because I was becoming afraid I might be able to lift this thing by myself!
Seriously though, they will provide not only the stiffness I want, but also simplify enclosing the build area to stabilize temperatures and allow for positive ventilation. I have pets in the office, and I'll be running a vent down thru the floor to the shop.
