Reprapro tricolour slave controller problem April 19, 2013 01:49PM |
SENDING:M503 echoteps per unit: echo: M92 X91.43 Y91.43 Z4000.00 E875.00 echo:Maximum feedrates (mm/s): echo: M203 X500.00 Y500.00 Z5.00 E45.00 echo:Maximum Acceleration (mm/s2): echo: M201 X1000 Y1000 Z50 E250 echo:Acceleration: S=acceleration, T=retract acceleration echo: M204 S1000.00 T1000.00 echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X15.00 Z0.40 E15.00 echo: M206 X0.00 Y0.00 Z0.00 echo
ID settings: echo: M301 P12.00 I2.20 D80.00 W125 FPU Enabled no
Re: Reprapro tricolour slave controller problem April 19, 2013 04:28PM |
Re: Reprapro tricolour slave controller problem April 19, 2013 08:29PM |
Re: Reprapro tricolour slave controller problem April 20, 2013 03:32AM |
Re: Reprapro tricolour slave controller problem April 20, 2013 04:21AM |
Re: Reprapro tricolour slave controller problem April 20, 2013 12:12PM |
Re: Reprapro tricolour slave controller problem April 20, 2013 12:39PM |
Re: Reprapro tricolour slave controller problem April 20, 2013 12:42PM |
Re: Reprapro tricolour slave controller problem April 20, 2013 12:45PM |
Re: Reprapro tricolour slave controller problem April 20, 2013 01:38PM |
Re: Reprapro tricolour slave controller problem April 20, 2013 02:05PM |
Re: Reprapro tricolour slave controller problem April 21, 2013 11:43AM |
Re: Reprapro tricolour slave controller problem April 21, 2013 01:20PM |
Re: Reprapro tricolour slave controller problem April 21, 2013 01:30PM |
Re: Reprapro tricolour slave controller problem April 21, 2013 03:02PM |
SENDING:T1 T0: 174.7/180 T1: 23.4/-273 T2: -273.1/-273 T0: 173.9/180 T1: 23.4/-273 T2: -273.1/-273 T0: 173.3/180 T1: 23.4/-273 T2: -273.1/-273 echo:Active Extruder: 1 >>>t2 SENDING:T2 T0: 171.8/180 T1: 23.4/-273 T2: -273.1/-273 T0: 172.5/180 T1: 23.4/-273 T2: -273.1/-273 T0: 173.0/180 T1: 23.4/-273 T2: -273.1/-273 echo:Active Extruder: 2 >>>t0 SENDING:T0 T0: 180.0/0 T1: 23.4/-273 T2: -273.1/-273 T0: 180.3/0 T1: 23.4/-273 T2: -273.1/-273 T0: 180.3/0 T1: 23.4/-273 T2: -273.1/-273 echo:Active Extruder: 0 >>>t1 SENDING:T1 T0: 175.7/180 T1: 23.4/-273 T2: -273.1/-273 T0: 174.9/180 T1: 23.4/-273 T2: -273.1/-273 T0: 174.2/180 T1: 23.4/-273 T2: -273.1/-273 echo:Active Extruder: 1 >>>t2 SENDING:T2 T0: 179.3/180 T1: 23.4/-273 T2: -273.1/-273 T0: 179.7/180 T1: 23.4/-273 T2: -273.1/-273 T0: 180.0/180 T1: 23.4/-273 T2: -273.1/-273 echo:Active Extruder: 2
SENDING:M503 echoteps per unit: echo: M92 X92.63 Y92.63 Z4000.00 E660.00 echo:Maximum feedrates (mm/s): echo: M203 X500.00 Y500.00 Z5.00 E45.00 echo:Maximum Acceleration (mm/s2): echo: M201 X1000 Y1000 Z50 E250 echo:Acceleration: S=acceleration, T=retract acceleration echo: M204 S1000.00 T1000.00 echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X15.00 Z0.40 E15.00 echo: M206 X0.00 Y0.00 Z0.00 echo
ID settings: echo: M301 H1 P12.00 I2.20 D80.00 W125.00 M301 H2 P12.00 I2.20 D80.00 W125.00 M301 H3 P12.00 I2.20 D80.00 W125.00 FPU Enabled no Axis 0 max: 210.00 Axis 1 max: 210.00 Axis 2 max: 140.00 Bed/extruder 0 beta: 4126.00 resistor: 4700.00 thermistor: 9999.99 inf: 0.01 Bed/extruder 1 beta: 3960.00 resistor: 4700.00 thermistor: 99999.92 inf: 0.17 Bed/extruder 2 beta: 3960.00 resistor: 4700.00 thermistor: 99702.65 inf: 0.17 Bed/extruder 3 beta: 3960.00 resistor: 4700.00 thermistor: 99702.65 inf: 0.17 Extruder: 0 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 180.00 operating temp: 0.00 Extruder: 1 dX: -42.00 dY: -32.00 dZ: 0.00 standby temp: 150.00 operating temp: 200.00 Extruder: 2 dX: -42.00 dY: 0.00 dZ: 0.00 standby temp: 150.00 operating temp: 200.00
Re: Reprapro tricolour slave controller problem April 21, 2013 03:22PM |
start Printer is now online. echo:Marlin 1.0.2 RRP echo: Last Updated: 2013-04-11 | Author: RepRapPro echo: Free Memory: 11130 PlannerBufferBytes: 1232 Slave init. Please wait ... ....................Slave init FAIL head 2 ok p:12.00 i:2.20 d:80.00 w:125 echotored settings retreived: echo
ID settings: echo: M301 H1 P12.00 I2.20 D80.00 W125.00 M301 H2 P12.00 I2.20 D80.00 W125.00 M301 H3 P12.00 I2.20 D80.00 W125.00 FPU Enabled no Axis 0 max: 210.00 Axis 1 max: 210.00 Axis 2 max: 140.00 Bed/extruder 0 beta: 4126.00 resistor: 4700.00 thermistor: 9999.99 inf: 0.01 Bed/extruder 1 beta: 3960.00 resistor: 4700.00 thermistor: 99999.92 inf: 0.17 Bed/extruder 2 beta: 3960.00 resistor: 4700.00 thermistor: 99702.65 inf: 0.17 Bed/extruder 3 beta: 3960.00 resistor: 4700.00 thermistor: 99702.65 inf: 0.17 Extruder: 0 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 180.00 operating temp: 200.00 Extruder: 1 dX: -42.00 dY: -32.00 dZ: 0.00 standby temp: 150.00 operating temp: 200.00 Extruder: 2 dX: -42.00 dY: 0.00 dZ: 0.00 standby temp: 150.00 operating temp: 200.00 transform correction not enabled
Re: Reprapro tricolour slave controller problem April 21, 2013 04:22PM |
Re: Reprapro tricolour slave controller problem April 22, 2013 09:49AM |
Re: Reprapro tricolour slave controller problem April 22, 2013 03:19PM |
Re: Reprapro tricolour slave controller problem June 11, 2013 12:36PM |
start echo:Marlin 1.0.4 RRP echo: Last Updated: 2013-05-08 | Author: RepRapPro echo: Free Memory: 11112 PlannerBufferBytes: 1232 Slave init. Please wait ... .Slave ready ok p:12.00 i:2.20 d:80.00 w:125 echotored settings retreived: echo
teps per unit: echo: M92 X92.63 Y92.63 Z4000.00 E647.00 echo:Maximum feedrates (mm/s): echo: M203 X500.00 Y500.00 Z5.00 E45.00 echo:Maximum Acceleration (mm/s2): echo: M201 X1000 Y1000 Z50 E250 echo:Acceleration: S=acceleration, T=retract acceleration echo: M204 S1000.00 T1000.00 echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X15.00 Z0.40 E15.00 echo: M206 X0.00 Y0.00 Z0.00 echo
ID settings: echo: M301 H1 P12.00 I2.20 D80.00 W125.00 M301 H2 P33.08 I33.08 D33.08 W29.76 M301 H3 P150.91 I198.62 D151.13 W198.62 FPU Enabled no Axis 0 max: 210.00 Axis 1 max: 210.00 Axis 2 max: 140.00 Bed/extruder 0 beta: 3480.00 resistor: 4700.00 thermistor: 10000.00 inf: 0.09 Bed/extruder 1 beta: 3960.00 resistor: 4700.00 thermistor: 100000.00 inf: 0.17 Bed/extruder 2 beta: 151.56 resistor: 199.90 thermistor: 19.95 inf: 12.00 Bed/extruder 3 beta: 2.20 resistor: 80.00 thermistor: 125.93 inf: 125.00 Extruder: 0 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 150.00 operating temp: 200.00 Extruder: 1 dX: -42.00 dY: 0.00 dZ: 0.00 standby temp: 150.00 operating temp: 200.00 Extruder: 2 dX: -42.00 dY: -32.00 dZ: 0.00 standby temp: 150.00 operating temp: 200.00 transform correction not enabledecho
D card ok
>>>t2 SENDING:T2 T0: 32.0/150 T1: 80.0/12 T2: 125.0/2 T0: 32.0/150 T1: -273.1/12 T2: -273.1/2 T0: 32.0/150 T1: -258.0/12 T2: -272.3/2 T0: 32.3/150 T1: -258.0/12 T2: -272.3/2 T0: 32.5/150 T1: -258.0/12 T2: -272.3/2 and so on.
Re: Reprapro tricolour slave controller problem June 11, 2013 03:24PM |
G10 P0 X0 Y0 Z0 S200 R150 G10 P1 X-42 Y0 Z0 S200 R150 G10 P2 X-42 Y-32 Z0 S200 R150
start echo:Marlin 1.0.6 RRP echo: Last Updated: 2013-06-06 | Author: RepRapPro echo: Free Memory: 10846 PlannerBufferBytes: 1232 Slave init. Please wait ... .Slave ready Firmware version: V08, EEPROM version: V08 ok p:12.00 i:2.20 d:80.00 w:125 echotored settings retreived: echo
teps per unit: echo: M92 X92.63 Y92.63 Z4000.00 E647.00 echo:Maximum feedrates (mm/s): echo: M203 X500.00 Y500.00 Z5.00 E45.00 echo:Maximum Acceleration (mm/s2): echo: M201 X1000 Y1000 Z50 E250 echo:Acceleration: S=acceleration, T=retract acceleration echo: M204 S1000.00 T1000.00 echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s) echo: M205 S0.00 T0.00 B20000 X15.00 Z0.40 E15.00 echo: M206 X-90.00 Y0.00 Z0.00 echo
ID settings: echo: M301 H1 P12.00 I2.20 D80.00 W125.00 M301 H2 P189.41 I146.06 D12.00 W2.20 M301 H3 P80.00 I125.00 D12.00 W2.20 FPU Enabled no Axis 0 max: 210.00 Axis 1 max: 210.00 Axis 2 max: 140.00 Bed/extruder 0 beta: 3480.00 resistor: 4700.00 thermistor: 10000.00 inf: 0.09 Bed/extruder 1 beta: 3960.00 resistor: 4700.00 thermistor: 100000.00 inf: 0.17 Bed/extruder 2 beta: 80.00 resistor: 125.00 thermistor: 5178.76 inf: 3960.00 Bed/extruder 3 beta: 4700.00 resistor: 0.17 thermistor: 0.00 inf: 3960.00 Extruder: 0 dX: 0.00 dY: 0.00 dZ: 0.00 standby temp: 150.00 operating temp: 200.00 Extruder: 1 dX: -42.00 dY: 0.00 dZ: 0.00 standby temp: 150.00 operating temp: 200.00 Extruder: 2 dX: -42.00 dY: -32.00 dZ: 0.00 standby temp: 150.00 operating temp: 200.00 transform correction not enabledecho
D card ok
Re: Reprapro tricolour slave controller problem June 13, 2013 06:46PM |
Re: Reprapro tricolour slave controller problem July 09, 2013 07:46AM |
Re: Reprapro tricolour slave controller problem July 09, 2013 08:03AM |
Re: Reprapro tricolour slave controller problem July 09, 2013 08:59AM |
Re: Reprapro tricolour slave controller problem July 09, 2013 06:44PM |
Re: Reprapro tricolour slave controller problem February 22, 2014 10:04PM |
teps per unit:
ID settings:
rinter stopped due to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting).|
Re: Reprapro tricolour slave controller problem February 22, 2014 10:16PM |
Re: Reprapro tricolour slave controller problem June 02, 2014 12:17PM |
