Strange problem with my pursa mendel...
June 06, 2013 12:37PM
Hello Repraprs
I encounter a strange problem with my pursa mendel (1.4), after i just finished to build it and calibrate it i loaded a 10mm cube for testing (using prontface). its took about 30 minutes until its heated the bed (that not the problem) so i tried to pause and reset the printing. After pushing the pause and the restart button the prontface crashed and since then the printer don't response (using prontface). when i upload the sprinter i do see the green light fleshes meaning there is communication.
I tried to unplug the power and usb cables and to reload the sprinter, but it didn't help...
Any solutions?
Thanks,
Adi.
Edited 1 time(s). Last edit at 06/06/2013 02:34PM by coteg.
Re: Strange problem with my pursa mendel...
June 06, 2013 06:46PM
I'd turn everything off, computer included, and try again. You might want to verify your com port, I've seen them move and return. You should end up in the port you started out with after a reboot though. Turn off all electronics for a full minute or so to clear residual power.
June 07, 2013 12:29PM
Pronterface is a buggy piece of software. I find it's sometimes necessary to disconnect the USB, exit pronterface, reconnect the USB, load pronterface and then connect to the printer. Might I suggest Repetier host? It's much better.
June 08, 2013 03:00AM
Hi guys,
Thanks for helping.
i tried to unplug everything, and the com setting are Fine, i also download the Repetier host and indeed its much better program.
when i'm connecting the printer i see this log:
09:44:46.751 : start
09:44:46.751 : SD Start
09:44:48.856 : SD init fail
09:44:48.856 : Soft PWM Init
09:44:48.856 : Planner Init
09:44:48.860 : Stepper Timer init
09:44:48.860 : Free Ram: 4233
09:44:48.864 : Plan Buffer Size:1152 / 16
09:44:48.872 : FIRMWARE_NAME: Sprinter Experimental PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1
09:44:48.876 : 00000000-0000-0000-0000-000000000000
09:44:48.876 : Unknown command:
09:44:48.880 : N2 T0 *24
does any one know why the log shows "Unknown command" ? (i read that N2 is related to checksum).
June 08, 2013 10:39AM
The problem was fixed, its seem that the print test has caused the power wire to melt...
i have 2 suggestion for the problem:
1. high current to the motors
2. lot of time for hitting the system up.
not very safety...
Thanks,
Adi
