First Print, what can I improve?
June 24, 2013 12:53AM
I have finally been able to make my first print on my recently assembled Prusa Mendel. It was supposed to be a cube. It was a good start, I guess, since I have seen worse. Maybe it need calibration. My heatbed is at 35c, and it can't go higher (i don't know why).
I have done no calibration at all, ais there a way to calibrate for this to improve?(bed and endstops are "calibrated")
Thanks,
TN
Edited 2 time(s). Last edit at 06/24/2013 12:56AM by tuficneme.
open | download - la foto (1).JPG (279.5 KB)
open | download - la foto.JPG (135.9 KB)
Re: First Print, what can I improve?
June 24, 2013 04:23AM
hi,
where O where,, the heat bed a major concern you got the correct settings in firmware??
tighten the grub screws on the pulleys seems reasonable, then check the current on the stepper drivers.hot smiley
June 24, 2013 10:56AM
You are losing steps along one of the axes. Could be a number of things. Just a few that I can think of off the top of my head:
-Insufficient current to the stepper motor (increase current slightly)
-Too much current to the stepper motor causing the drivers to overheat and cut out (motor will be hot, decrease current)
-Pulley slipping on the shaft (tighten the set screws)
-Belt slipping on the pulley (tighten the belt)
As for the bed, make sure your power supply can put out the necessary amps and make sure you have the correct thermistor selected in your firmware. That temp is far too low.
June 25, 2013 03:54PM
Thanks aloot!
I fixed a belt that was kind of loose, now it printed of better. Any other tips to improve this?
My heatbed went up to 40c, but it took 30 minutes to get their. What could be wrong?
open | download - photo 3 (3).JPG (107.5 KB)
open | download - photo 1 (6).JPG (145.4 KB)
June 25, 2013 07:03PM
I had the same problem with my Durbie Prusa. The resistance of the heated bed I received is about 6 ohms, which means that with a 12V supply, it's only being heated with 24W. I'm now using a separate 24V transformer to power the heated bed, using a solid state relay to have the board control it, and it heats up in good time, about 10 - 15 minutes to reach 100C.
Regards;
Rick
June 25, 2013 09:41PM
really? My HB also measures around 6Ω, I'm using RAMPS 1.4 with the recommended Mosfet and an ATX PSU providing 12V. My heatbed reaches 105C in about 2-3 minutes, 10 mins is a ridiculously long time to wait in my opinion
June 26, 2013 09:45AM
Interesting... Do you have insulation under the bed? I put a piece of cardboard on top while it's heating, but I don't have anything underneath. I'm planning to put some insulation underneath now, because I just had to take the bed off to replace the tape.
June 26, 2013 10:23AM
rick55 Wrote:
> using
> ATX
> long
> replace the tape.
No I don't have any insulation, I have an aluminum build platform with a silicon heat bed that is kind of like a giant sticker, I just stick it to the underside of the build platform. So aluminum bed with a heat bed sticker (kind of looks like the one's on trinity labs' website) and nothing under the "sticker"
June 26, 2013 11:36AM
> > using
> > ATX
> > long
> [ snip ]
> under the "sticker"
Wow - that's obviously more efficient that PCB, if it heats in a couple of minutes on 24W. I'll have to look at it.
