Printrboard heatbed output, won't turn off now June 25, 2013 08:14AM |
Re: Printrboard heatbed output, won't turn off now June 25, 2013 01:07PM |
Re: Printrboard heatbed output, won't turn off now June 25, 2013 09:17PM |
Re: Printrboard heatbed output, won't turn off now June 25, 2013 09:56PM |
Re: Printrboard heatbed output, won't turn off now November 10, 2013 01:50AM |
Re: Printrboard heatbed output, won't turn off now November 10, 2013 08:43AM |
Re: Printrboard heatbed output, won't turn off now November 13, 2013 02:18PM |
Re: Printrboard heatbed output, won't turn off now November 20, 2013 05:01PM |
Re: Printrboard heatbed output, won't turn off now November 22, 2013 03:33AM |
Wired1
I am a big fan if the Printrboard, it is the simplest and fastest one board controller I have used and with the bootloader option is as easy to use as anything else out there - and it is cheaper too. However... and there is always a big BUT with anything cheaper it seems, they do have an issue with the output mosfets blowing. I guess they were never designed for the higher current capsule elements and hot beds we are now using. It is the only way I have seen to kill them other than a mate who hooked up the power supply the wrong way around. I am replacing one on a Prusa I built a few years back and this time I'm going to add relays to switch the hot end and heated bed. The other design flaw with the printrboard is the power connection and pin headers melting under load and the relays will fix this problem too. I'll post some pictures and a wiring diagram when I've done it but basically you use the MOSFETs to switch the relay instead of the heated bed or hot end, once you remove this load from the board the rest of your problems disappear, at least that is my hope.
Re: Printrboard heatbed output, won't turn off now November 22, 2013 12:09PM |
