Building a levelling jig
July 13, 2013 02:25PM
I've designed a leveling jig that will hold a dial indicator and level the table within a few thousands of an inch for some really awesome prints, but I need a copy of the X shaped mount in a .dxf format so I can edit it to fit leveling nuts to replace the stock ones.
Is it possible to get a copy of that in a format that I can modify it? I don't have any software that can work with .stl files (I use RhinoCAM).
Or is there any decent software to convert mesh to .dxf?
www.srcgunworks.com
open | download - _SAM1005.JPG (565.3 KB)
Re: Building a levelling jig
July 13, 2013 06:05PM
RhinoCAM website says it can import stl?
Ben
July 13, 2013 08:46PM
It can read the .stl, but I can't do any editting to it like I can a .dxf.
www.srcgunworks.com
July 14, 2013 10:10AM
You'll have to figure out to do subtraction in your modeling software and subtract the nuts from the stl object. In openscad this is called difference.
July 14, 2013 04:13PM
I found a way for Rhino to convert mesh to polysurfaces, thanks for your input. But I cannot find a copy of the X part to work with.
www.srcgunworks.com
July 14, 2013 04:57PM
Do you mean the Y carriage? All the ecksbot files are here. http://www.thingiverse.com/thing:26354
Blog
July 14, 2013 06:10PM
Thanks, don't know why I couldn't find it!
www.srcgunworks.com
July 27, 2013 05:14PM
I made some of these up out of Aluminum; the mount is glass beaded and the nuts are polished.
Comes with a dial indicator.
[www.srcgunworks.com]
www.srcgunworks.com
