motors stalling
Posted by saldurable
motors stalling
July 13, 2013 11:30PM
hello reprap forums i connected all of my electronics and am using pronter face to test the motion of the axes on the prusa i2 i built. However all of the motors are stalling except for y axis in only one direction. I am using ramps 1.4 and 5 nema 17 motors. I only have the 12v 5 amps power connected and am wondering if it does not have enough power or is it a friction problem.
thanks,
saldurable
edit: if it helps i am using a 600 watt pc power supply
edit: never mind i thing i got it
Edited 2 time(s). Last edit at 07/13/2013 11:45PM by saldurable.
Re: motors stalling
July 14, 2013 08:25AM
You should post what was the problem in order to help people who encounter the same problem winking smiley
Re: motors stalling
July 22, 2013 03:33PM
Hi, can you tell uss what you did?
Re: motors stalling
August 05, 2013 09:33AM
I'm guessing he figured out to home the axis' first.
Re: motors stalling
August 05, 2013 07:57PM
Im guessing either it was an issue with not or incorrectly positioning pots on the ramps board. It could also be your power supply. Why would you only connect a 12v 5 amp line on your psu if it is a 600 watt one you should have a 12v line with like 50 amps Available. Then again he could have missed aligned rods.
--------------| For Everything |--------------------------
Check it out here:
[reprapsquad.wordpress.com].
---------| For Everything Prototype Related |------
Now featuring comp case mods:
[RepRapLab.wordpress.com]
--------------| Find us at Twitter|------------------------
@REPRAPSQUAD (RS Main)
[mobile.twitter.com]
@REPRAPSQUADHQ (ProtoLab)
