switched to abs now prints go bad after first layer.
Posted by jackabus
July 14, 2013 03:59PM
Not sure first it was a jammed extruder. Now filament seems to stop extruding after the first layer. I have a good first layer. I slow the first layer down. All works fine with pla I change the temp 230-250 in slicr3 and resliced for abs not sure what has changed.
open | download - IMAG3824-1.jpg (258.1 KB)
Re: switched to abs now prints go bad after first layer.
July 14, 2013 07:06PM
I'm guessing you need a higher temp on your hotend. It looks like you extruder isn't keeping up when it speeds up on the next layer.
Rodney
July 20, 2013 08:39PM
ABS is a totally different animal
have to work out the speed that you print at what speeds did you first try looks like first layer printed okay so it could be when it speeded up to do the remaining layers it was too fast try slowing it down little
