What is my next step?
Posted by Itek
July 18, 2013 01:41PM
Hello. grinning smiley
I have just buildt my machine, installed Pronterface and I have confirmed that everything is working, steppers, heatbed, extruder and hotend.
My question is quite simple, what do I do now?
I would expect that I have to do some adjustments and calibrations. How? What are my tools?
I Installed Arduino and sanguino, but Im a bit stuck. Couldnt download all files correctly and thats why I didnt finish ( I got some htm files).
Any help will be appreciated!
Edited 1 time(s). Last edit at 07/18/2013 01:42PM by Itek.
Re: What is my next step?
July 18, 2013 01:45PM
I'm don't know what your stuck at, but after your printer is working, goto the calibration wiki and download the calibrations stl's and go from there.
July 18, 2013 03:07PM
Thanks..
Hmm, by saying everything is working, what I really ment is that everything is moving :/
BUT...I found a page about comissioning.
Now I have to measure to set current limits on my pololus/stepper drivers...
Trying to measure some voltage between the pot(or Vref) and ground while the motors is running. I cant get any readings... why?
July 19, 2013 04:52PM
Yihaa!
I just did my first dry print (no filament). Wrote down a couple of things I´ll have to fix.
But, there is one thing Im wondering about. I cant read my SD card when its installed in the printer... "echoconfused smileyD init fail". And then I get an empty list...
Anyone know what this might be? I have formatted the SD card (FAT), but still the same; echoconfused smileyD init fail...
Btw, this is my kit:
MendelMax 1.5+ from ultibots.com
July 20, 2013 02:18PM
I sendt an email to ultibots about the SD card init fail
Now Im struggling about hotbed and heat, getting the ABS to stick to the bed. I almost made it work, but on layer 2 everything came loose. I found out that I`ll have to order some kapton tape, the PET tape which was included in the kit is not good enough for abs...
July 24, 2013 01:45AM
Is this correct?
1: Glass
2: ca 2mm aluminium plate
3: heat plate/element
I think this is a little weird, the aluminium plate will bend and the heat will not conduct to the glass in the middle. My supports are in the corners. I have some clips, but they do not help much...
Edited 2 time(s). Last edit at 07/24/2013 02:53PM by Itek.
August 21, 2013 10:57PM
Itek -
I am not sure what is going wrong with your printer and I would like to help.
We have been successfully printing 100+ kilos of ABS with the MendelMax 1.5+ exactly like your kit using ABS Juice on PET tape.
I wish I had found your posts sooner. Please email us directly at support )at( utlibots dotcom.
Thanks,
Brad Norman
Owner - UltiBots
