Make sure you have setup your "sketchbook" folder (normally my documents/arduino) and that your IDE is pointing to it.
In this folder you should have 3 sub folders called hardware, libraries and sketchbook.
Witthin this folder you need to copy your Sanguino / gen6 / gen7 (depending) addons into the "hardware" folder.
The arduino.h file should be in the "cores/arduino" folder within.
Restart the IDE.
Try that!
Edited 1 time(s). Last edit at 07/31/2013 08:07AM by slymike.
