Layer height - line height vs width? July 30, 2013 11:45PM |
Re: Layer height - line height vs width? July 31, 2013 03:21AM |
Re: Layer height - line height vs width? July 31, 2013 11:06AM |
; layer_height = 0.2 ; perimeters = 3 ; top_solid_layers = 6 ; bottom_solid_layers = 6 ; fill_density = 0.4 ; perimeter_speed = 40 ; infill_speed = 70 ; travel_speed = 130 ; nozzle_diameter = 0.5 ; filament_diameter = 3 ; extrusion_multiplier = 1 ; perimeters extrusion width = 0.85mm ; infill extrusion width = 1.02mm ; solid infill extrusion width = 0.85mm ; top infill extrusion width = 0.85mm ; first layer extrusion width = 0.80mm
; layer_height = 0.4 ; perimeters = 3 ; top_solid_layers = 6 ; bottom_solid_layers = 6 ; fill_density = 0.4 ; perimeter_speed = 40 ; infill_speed = 70 ; travel_speed = 130 ; nozzle_diameter = 0.5 ; filament_diameter = 3 ; extrusion_multiplier = 1 ; perimeters extrusion width = 0.53mm ; infill extrusion width = 0.53mm ; solid infill extrusion width = 0.53mm ; top infill extrusion width = 0.53mm ; first layer extrusion width = 0.80mm
layer height 0.1 0.2 0.3 0.4 0.5 --------------------------------------------------------------------- perimeters extrusion width 0.85mm 0.85mm 0.70mm 0.53mm 0.53mm infill extrusion width 1.98mm 1.02mm 0.70mm 0.53mm 0.53mm solid infill extrusion width 0.85mm 0.85mm 0.70mm 0.53mm 0.53mm top infill extrusion width 0.85mm 0.85mm 0.70mm 0.53mm 0.53mm
Re: Layer height - line height vs width? July 31, 2013 11:35PM |
Re: Layer height - line height vs width? August 02, 2013 11:20AM |
Re: Layer height - line height vs width? August 02, 2013 07:21PM |
Re: Layer height - line height vs width? August 03, 2013 02:29AM |
