Prusa i3 10mm Y Corners
Posted by matrix4721
August 07, 2013 08:32AM
Hi all
So ive decided to build the Prusa i3 and im currently in the process of printing the STL's for it and ive come across a minor issue, ive decided to make the Einstein version as i like the use of the 10mm threaded rods however i want to use 10mm smooth rod instead of the standard 8mm, sadly i cant find an STL that uses 10mm on both the threaded and smooth rods, they either have 10mm threaded and 8mm smooth or vice versa, anyone happen to know where i could find it please? many thanks
Re: Prusa i3 10mm Y Corners
August 10, 2013 11:09PM
I don't know where you can find ones pre drawn for 10mm smooth, but the source SCAD files are located here. You could use OpenSCAD to modify them.
August 11, 2013 10:14AM
This should have the STLs that you're after. It has 8mm smooth rod and 10mm threaded rod.
http://www.thingiverse.com/thing:119616
August 11, 2013 11:04PM
> http:
I think hr wants 10mm smooth rods too.
August 12, 2013 09:58AM
Enjoy!
open | download - y-corners-10mmRods v2.stl (29.2 KB)
September 02, 2013 07:16PM
Amazing, thank you very much, ive printed them off and they are perfect, very happy here smiling smiley
