weird z-homing problem. Been stuck for days... [SOLVED]
Posted by tobben
August 22, 2013 01:25PM
Hi all!
I'm building myself a custom Reprappro Mendel, but are having troubles getting z home to work.
When I send G28 Z (home z axis) the z-axis moves ca 1 cm in the wrong direction at the fast home feedrate speed. It behaves as if I sent it G1 Z10, just slower. No bounce back. Tested with different versions of Marlin, same result.
Sending M119 gives me "z_min:H" no matter how what I do with the endstop swich terminals (like shorting, unplugging or trying different swich). I've looked for shorts on the Melzi board without any luck. X and Y homing works as expected...
Configuration.h
Any suggestions?
Edited 1 time(s). Last edit at 08/22/2013 06:37PM by tobben.
torbjornludvigsen.com
Re: weird z-homing problem. Been stuck for days...
August 22, 2013 04:54PM
Measured pin 20 on the atmega 1284p. It jumps between 0 V and 5 V when endstop swich is pressed, exactly as it is supposed to. pins.h contains
#define Z_MIN_PIN          20
just as it should do. Where to look for errors now? confused smiley
August 22, 2013 06:11PM
I only get the correct jumping between 0 V and 5 V if I measure in the "measurment hole" beside the processor. It turns out that if I measure directly on the pin solder, it gives a constant 5 V. Carefully measuring resistances between holes and pins with power unplugged shows a bad soldering job on pin 20. Oh my, hope I am able to fix it, and hope it's the only one...
Re: weird z-homing problem. Been stuck for days... [SOLVED]
August 22, 2013 06:37PM
Guys, I made it. The machine works now. Lession learned: If your pin 20 on your atmel 1284p is not connected to your Melzi PCB, the consequence is that z-home jogs ca 1 cm upwards instead of heading down towards the swich (well, at least if you try to use Marlin).
Thanks for rubberducking me, hope this helps someone smiling smiley
