Re: Hot motors November 02, 2013 10:29AM |
Re: Hot motors November 02, 2013 12:49PM |
Re: Hot motors November 02, 2013 07:37PM |
uncle_bob
You are trying to drive a sinusoidal constant current through the motor. The frequency of that sinusoid (AC current) is determined by the speed (revs/second) of the motor times the number of full steps per revolution. If your motor runs at 6.5 revs/sec and you have a 200 step motor then the frequency would be 6.5 x 200 = 1300 Hz. You can look at the magnitude of the impedance presented by the coil inductance and the coil resistance at that frequency and pretty quickly determine if you have enough voltage to do the job. For most of these motors the inductance is not large enough to increase the impedance much at all at ~ 1 KHz. The motor is essentially a pure resistance at the frequencies we step them at.
Re: Hot motors November 03, 2013 05:30PM |
Re: Hot motors November 03, 2013 05:54PM |
Re: Hot motors November 03, 2013 06:24PM |
