My 3D Printer Worklog (Mix G1) - Part 2
Mechanical Assembly
(As a note I'm about a week ahead in progress from this post.)
The assembly went decently well, after the first few steps, as part of the assembly video from the creators here:
www.youtube.com]
What confused me quite a bit was that the base pieces were completely different from the video. You essentially ignore 0:16 to 0:56 in the video because the power plug and switch have plastic housings, and the side plates that used to go in the YZ plane do not exist with the new printer design. Just put the "Base Part 1" and "Base Part 2" together, and
do not attach this stuff to the base until the Y motor is attached.
It's hard to see in the web page, but the way all of the stuff is supposed to go is like this:
I changed around the wiring layout - described in the next part. My main issue is this:
Do they ACTUALLY expect you to run a 110V-240V line from one corner of the printer, underneath all the nice moving parts of the Y-axis to the plug? As I'll be saying this a lot about the electronics for this printer. How about... no!
Also something I figured out was to just hand-tighten all of the nuts and threaded rod until the final calibration, because I was loosening and re-tightening stuff all over when it came time to attach the X axis.
Aside from that, the assembly went pretty much as it went in the video. I did however have to toy with the Y-axis to get it right later on.
Electronics Assembly
I have to credit the Mix G1 people for the mechanical design of the printer. Despite the way it relies on the nice alignment of the two base plates for the Z-axis being right, mechanically it is pretty sound. I moved the printer around quite a bit to bring it from where I work on it to where I can print without having to suck fumes (BTW I'll tell you this early - that fluorescent yellow ABS Mixshop sold me is borderline hazardous with the amount of fumes it generates). All the moving around - upstairs, downstairs, to the garage, etc. and the I haven't broken anything major / the most realignment I had to do was the 4 screws to level the build plate.
The electronics however looked a lot like an afterthought, because they didn't provide good spots for wire ties / zipties / spiral wrap, and in my opinion, a lot of the wire was too small. The thickest wire I found in the kit was 20AWG.
Depending on the length of wire, the heatbed would lose some of its efficiency.
Math:
(Wire guage chart [
www.daycounter.com])
Assuming you use about 1m of wire from the power supply, to the ramps, to the heatbed, and back...
Not counting the connections, that 1m of wire has 0.03 Ohms of resistance.
Using the measurement of my heatbed at 1.4 Ohms and the wire measurement, that means the 1m of 20AWG wire has about 2% the resistance of the heatbed. (Power = Resistance * Voltage squared) I'd rather have that 2% of power for heating my bed and not my wire, thank you very much!
I used 14AWG wire for the wires between the PSU and the RAMPS and the RAMPS and the heatbed, and 18AWG wire for the extruder. Also to keep connections from getting loose, I tinned the wire (coated with solder) that went into the screw terminal on the RAMPS board and used ring terminals to connect to the power supply. Unlike the video in which the author had some obsession of using Kapton tape for everything, I used heat shrink tubing.
I changed the layout of the base plate to put the power supply, switch, and plug all in the same corner:
That means all the 110V fun is contained to less than 15cm lengths of wire and all at the same corner. I ran the 12V wire over top of the 110V stuff as well, so if the bed were to crash against the wire it would get the 12V and not the 110V.
To prevent the extruder from hitting its own wires for any Z, I glued a post to the top z holder and from there I ran an elastic band which I tied to the wires. The extruder wires then tie to the "unused" bit of smooth bar on the +X side of the printer. (Plan is to try some spiral wrap there as well.)
In case you need to twist a long length of wire in a hurry, throw it in a hand drill! (don't use the part that was in the drill though)
For the heat bed, I wired it "upside down" from the video. (The holes are just big enough for 14AWG wire BTW)
I put the thermistor on the back side of the bed and I plan to use the side with the traces for the heating. I bought some cheap glass (actually asked local glass shop for the cheapest 3mm stuff) and that was mounted on the side with the traces. With this config, I know my temperatures will read lower than some, but I get the heat where I want it - on the side that prints. The other advantage is the thermistor gives a better idea of what the temperature is, rather than always being exposed to a higher temperature than the print surface.
Note after taking the picture I put some Prolimatech thermal compound over the thermistor and Kapton tape over all of that. I also used that thermal compound for the thermistor and the wire wound resistors on the extruder. I'm using some old stuff that came with a Megahalems heat sink that I got for my computer, so I wouldn't know if it's the same stuff as the PK-1 that they sell now. In any case, the heating / cooling works well enough for me to print ABS and PLA with.
Next up: First prints
