Fixed torn USB receptacle
August 24, 2013 03:24PM
Hey all,
First time poster. I have a RepRap Mendel mono. I have enjoyed learning how to create good prints. I recently had a problem, and I wanted to share the fix with anyone else that might have the problems.
I was moving my printer, and unplugged the USB cable from my computer, but I forgot to unplug the other end of the cable from the USB receptacle on the controller board. When I got to my destination, I was sick to see that my cable had caught on something and torn the receptacle was torn off except for a dangling thread.
At first I hoped that I might be able to solder the receptacle to connect back to be board via wires, but then one of the leads broke off as I attempted to manipulate it. To make a long story short, with the help of Ian from RepRap support, I found the following:
--Here is a link to the wiring schematic of the controller board: Controller Board Schematics .
--Here is a closeup picture that shows how the receptacle is normally attached. It is the part on the bottom with a yellow-colored membrane on its surface
I am fairly certain that the receptacle is a "micro B" type connection. The pins are numbered from 1 on the left to 5 on the right, as shown here:. And here is a good reference for the various USB connections.
(FYI: Pin 4 doesn't do anything. I'm not going to into much of a discussion about this.)
I was initially confused about pin 5, as I couldn't trace that it did anything by just looking at the board. Notice from the image that pins 1-3 have surface wires running away on the controller board to other parts. Even the schematic didn't seem to show pin 5 doing anything, as seen below (Note: this is the schematic for the same part of the controller board shown above):
I then noticed that it was supposed to be connected to ground, as shown on this part of the schematic:
I wasn't sure exactly how to connect pin 5 to ground. I thought that the large blocks on the schematic that represent the attachment points for the usb receptacle would be ground, but it wouldn't work when I attached there. With testing with a multimeter, I determined that one of the empty connector holes did connect directly to ground. On the schematic diagram, I used the open hole below and to the right of the bottom right large attachment block for the usb receptacle. There are two holes side-by-side. The I used the empty one on the right. See also photo below for placement. There are likely also many other places that a ground wire could have been attached.
I used the fine wire that came with my RepRap kit, individual strands of the ribbon wire that was provided. When the metal strands are neatly twisted, they pass nicely through the connector holes on the controller board. I am not a super good solderer, but I was able to get the get the job done. I didn't think that if I tinned the wires before hand, that I would then be able to pass them through the holes. So left the wire a bit long, applied the solder onto the protruding tip on the backside of the board, and then quickly pulled the wire and solder back a bit so that it cooled and made a firm connection. Here is a picture showing the connections. It is difficult to see exactly where the wires are connected. Comparing to the schematic above will help.
After I had the wires connected to the controller board, I next needed to connect those wires to the USB. I couldn't use the receptacle I had, since one of the wire leads had broken off, so my best option was to hard-wire the cable directly to the board. I opened up the micro end of the USB cable, and found 4 coated wires, and some surrounding shielding wire. And mixed in with that shielding wire was a copper ground wire. To determine which wires to connect to which, I referred to this diagram of the A-type connector, which goes into the computer. Notice that there are only pins 1-4. The metal casing of the A end connects to the ground wire (pin 5) on the controller board.
I got it all connected, and Hallelujah, it worked! I firmly attached the fragile wires to the printer frame with zip-ties to prevent further problems. I have been able to connect to the board from my computer and print more 3d objects out.
Here is a large picture of the overall fix.
A word to the wise. I recommend that other users with this same printer arrangement to do SOMETHING to secure the USB cable to the frame as a shock guard. A simple zip-tie would work, or someone could create some clip that is more easily reversible. I hope I am the only one to ever have this problem, but it seems that without some sort of guard that others will face the same horror I did.
Best Wishes,
Kevin Toppenberg
Edited 2 time(s). Last edit at 08/24/2013 03:28PM by kdtop.
Re: Fixed torn USB receptacle
August 26, 2013 05:56PM
Excellent work Kevin! I've put a link to this on the Melzi page: [reprap.org]
Ian
RepRapPro tech support
Edited 1 time(s). Last edit at 08/26/2013 05:57PM by droftarts.
August 27, 2013 06:06PM
Thank you, too, Ian. I'm glad to be back in business. :-)
August 28, 2013 01:49PM
> board shown above):
> schematic:
In the PCB layout view, Eagle does not show pads as connected if the actual connection is to a filled area such as a ground plane. I think the board has a ground fill on the top side so it only appears the pad is not connected. If you look at the Gerber file it should show as being connected, usually with a "thermal relief".
I never figured out how to get Eagle to show fills in preview, it is easy to do in Kicad.
ETA: I had a look at the gerber file, this is the part around the USB connector.
Assuming that the gerber corresponds to the board you have, you can see that pin 5 is connected to the ground fill, but if the pad was pulled it would be quite easy to damage this trace.
Edited 3 time(s). Last edit at 08/28/2013 02:03PM by bobc.
open | download - melzi_usb.png (7.3 KB)
August 29, 2013 10:13AM
This is very interesting. I agree that the pin 5 must have been connected to ground, and I just couldn't see it when the receptacle got torn off.
Can you tell me more what "Eagle" is? And by "PCB", is that the view that I posted?
Thanks
Kevin
August 30, 2013 04:59AM
PCB is the electronics board alone (without components soldered)
[en.wikipedia.org]
Eagle is a software aimed at designing PCBs
[en.wikipedia.org]
August 30, 2013 09:05AM
Thanks for this Kevin, I've taken a PDF copy and put it in my 'userful bits of information' folder.
Fortunately I've not had this problem (yet(!)). But when I build my Mendel Mono in July I was concerned about something like this happening, and to help prevent it I ran the usb cable down the front left diagonal screwed rod and along the bottom one that crosses the frame, securing it to the rods with some zip ties, and leaving a generous loop where it goes to the socket on the the controller board,
Harvey
October 03, 2013 12:11PM
A customer asked for a better picture of the connections, so I have done the attached.
Ian
Edited 1 time(s). Last edit at 10/03/2013 12:12PM by reprappro.
open | download - RRP_USB_fix.JPG (219.4 KB)
October 03, 2013 01:15PM
Much better! Thanks!
Kevin
October 04, 2013 07:43PM
Why I hate surface mount connectors! Especially for usb...
October 30, 2013 07:52AM
Excellent and very useful post
I had the same accident,but fixed it using your method.
When I cut the USB cable I found 4 wires.
Using your diagram I attached/soldered the wires directly as follows.
RED 1
WHITE 2
GREN 3
BLACK 5
October 30, 2013 06:37PM
Excellent. My heart just sunk when I had this problem. Glad I could help you get back going again.
Kevin
December 02, 2013 11:17AM
hi
Exelent post ! got everything fixed and the printer is running again.
i had problems to get the ground in this tiny hole so i solder it to the food of the sdcardcase.
also made some pictures:
1. unmount the melzi
2. make 4 tined cabels
3.solder them to the usb female
4.Check this ! realy!
5. Isolate the pins
6. solder the freeends of pin1 to3 to your melzi
7. solder ground(pin5) to sdcard ground
8. do all the wiring as usual and FIX the ubsplug that this NEVER can happen again
let me know if this is not needed anymore or someone did better so a can clean up.
mekmekmek
Do not buy what you cannot recycle!
Edited 4 time(s). Last edit at 12/02/2013 12:52PM by mekmekmek.
March 03, 2014 05:53AM
I have killed two boards this way. Hopefully I can get at least one back. Thank you so much for posting this.
April 08, 2014 03:10AM
Hi, does anyone bin BIOS to Melzi ardentissimo ATmega128 16MHz?
I accidentally lost the it when I rewrote fgtech galletto2.a now the printer shows as fgtechgall. I need to eeprom bin.
July 24, 2014 11:31AM
Had the same problem. Your fix worked great! Thanks so much.
July 24, 2014 03:33PM
I've seen products that use a surface mount usb port like this but that have a small block of plastic bolted over the socket so that it can't be ripped off.
Ben
July 29, 2014 06:29AM
Great Kevin, thanks..
Also I had this problem, 10 minutes after receiving the printer and busy installing it...a bad feeling when you have a detached usb connector in your hands sad smiley
I found your solution and noticed immediately I have a different version of Melzi board (brand rp3d.com) with different printlanes and also less obvious spaces to solder. However all suggestions in this thread helped me to solve the issue. The differences with your approach is that I have (had to) solder the wires to the original usb connections. Which looked like a difficult task, as these lanes are very tiny, but with the help of a big loupe, a steady hand (not mine smiling smiley) and a very tiny solderingtip it could be done.
Addionally I have chosen to connect a usb-mini female connector. I bought a cable with a usb mini female connector and cut the other side. Those wires (same colors accordingly to the diagram mentioned in this thread) have been soldered to the board. The cable I have attached with tie-raps to the frame of the printer. So I can use a standard usb cable to connect the printer with the laptop and whenever somebody would pull the cable again, it pops out of the new connector.
For all attached a picture of my repair.
Icarus 3D-M2L printer (Mendel with Melzi)
open | download - USB Melzi.JPG (64.3 KB)
January 14, 2017 04:16PM
Super Kelvin ;-)
Thanks to you I was able to help myself, I had to locate the connections, but I had not seen that there were two "GND", I connect them and it is OK.
Thanks for this post.
Super Kelvin ;-)
grace à toi j'ai pu me dépanner, j'avais bien repérer les branchements, mais je n'avais pas vu qu'il y avait deux "GND", je les est relier et c'est OK.
Merci pour ce post.
December 30, 2017 07:56AM
Sorry for the delay in reply. I don't get on this forum very much. I am very happy that I was able to help!
Kevin
February 04, 2018 01:57PM
Yes! It still works. Thanks.
April 20, 2018 04:35AM
Thank you for this, i manged to fix mine
April 20, 2018 09:19PM
Great!
