My first RepRap Graber i3-aluminium frame
Posted by biszkopt80
September 14, 2013 04:06PM
Hi All!
My name is Damian, and I'm a new RepRapper.
I'm build my first RepRap Graber i3
I have minimal budget, but I have a lot of persistence, and patience.
My frame is build from aluminum 6082 T6 , 6mm thickness.
I'm trying to build all using only laser cut parts because i have access to laser and waterjet as well.
I'm using 8 mm 316 stainless steel rods, and LM8UU 8mm Linear Ball Bearings
Threaded rod is 6mm stainless steel
I plan to use RAMPS 1.4 electronics
Thanks for any good and bad words about my build
Edit: to fix a spelling mistake that was a bad word
Edited 1 time(s). Last edit at 09/14/2013 05:53PM by NewPerfection.
Re: My first RepRap Graber i3-aluminium frame
September 14, 2013 05:54PM
Looks nice. The only thing I would recommend is that the smooth rods be hardened. Otherwise the LM8UU's will wear grooves in them.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
October 21, 2013 07:23PM
Hello Damian
Im also new in Reprap, and I like a lot the model you have printed out.
can you give us an update of the evolution?
I have some doubts... for expample: How many kilos weighs?
how is the x carriage? do you photos with the belts and the motor on it?
thanks
J.
October 23, 2013 06:18AM
UPDATE
X and Y axis get motors and GT2 belts
Edited 1 time(s). Last edit at 10/23/2013 06:59AM by biszkopt80.
November 24, 2013 05:17PM
Little update
First test of my i3
My i3 on Youtube
February 02, 2014 09:02AM
Did you use the original design files or did you change anything for the 6 mm ?
February 02, 2014 10:45AM
I done few changes but not in material thicknes,i have new z axis mount
