Frustration: Hole inner dimensions all 0.5mm under size, help! October 01, 2013 04:12PM |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 01, 2013 05:25PM |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 01, 2013 05:40PM |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 01, 2013 06:39PM |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 01, 2013 07:14PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 02, 2013 03:16AM |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 02, 2013 12:18PM |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 02, 2013 01:06PM |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 04, 2013 07:36AM |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 04, 2013 12:32PM |
Cura has a strange way of doing this and you need to do the math and figure out the width you want to extrude multiplied by the number of perimeters you want and then enter that as the wall thickness. This has nothing to do with flow rate and E steps per mm.| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 04, 2013 12:43PM |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 04, 2013 01:06PM |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 04, 2013 01:46PM |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 05, 2013 10:48AM |
slarti42uk
* Filament: Diameter - 3mm
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 06, 2013 11:13AM |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 06, 2013 12:26PM |
Re: Frustration: Hole inner dimensions all 0.5mm under size, help! October 08, 2013 08:50AM |
