What is DRV8825 driver?
Posted by bardiaesm
October 01, 2013 07:10PM
I'm looking to purchase Megatronics 2.0 board and I was going through this page (http://reprap.org/wiki/Megatronics_2.0).
I saw a part about using DRV8825 driver for my step motors but I have no idea what they are!
I could not find anything online so please tell me what it is, what does it do and does it worth buying?
Thanks
Edited 1 time(s). Last edit at 10/01/2013 07:22PM by bardiaesm.
Re: What is DRV8825 driver?
October 01, 2013 09:33PM
ok so basically you need to have drivers for each axis and each extruder, the driver is a chip that runs the stepper motor. there are two reprap compatible drivers, the 4988 or whatever and drv8825. the drv8825 is better because it allows for a higher amperage motor, but ive heard the 4988 can actually step at a higher rate, theoretically, not that you could acheive that rate with a loaded motor anyways. also the drv8825 has 32 microstepping.
microstepping is like adding more steps in between each step.
October 02, 2013 08:53AM
Thanks for your answer @aduy,
So do you have to have that kind of driver in order for the step motors to work, or does the board already come with working drivers?
October 05, 2013 10:09PM
You can use 4988 drivers or drv8825 drivers but you will need one or the other for the board to work.
October 05, 2013 10:17PM
My board has slots so you can plug in the driver externally, however there are some boards that have them built in.
October 05, 2013 11:55PM
Go to pololu.com and look at their stepper drivers. You will see both kinds there and can compare for yourself.
October 07, 2013 12:51AM
the main difference between A4988 and DRV8825 is that DRV8825 can do higher amps, as well as 1/32 micro stepping, A4988 can only do 1.5A and 1/16 micro stepping
___________________________________________________
Kreativ-e
Tinkerine Studio
