Budaschnozzle Hot End (modified ) version overcome leakage problem
October 10, 2013 04:19AM
Here is modified version of budaschnozzle which overcome my printing leakage problem
It combines the nozzle and filament barrel
It keeps nozzle clean
and easy to assemble with middle surface area .
Below is youtube link
[www.youtube.com]
Edited 1 time(s). Last edit at 10/10/2013 04:20AM by sach00.
open | download - IMG_20130916_161754.jpg (261.7 KB)
open | download - IMG_20130916_161809.jpg (318 KB)
open | download - IMG_20130916_162504.jpg (407.2 KB)
Re: Budaschnozzle Hot End (modified ) version overcome leakage problem
October 12, 2013 10:54AM
How did it leak and how does what you did solve it?
October 17, 2013 07:25AM
please find the attach pla leaking pic
open | download - IMG_20130916_160822 - Copy.jpg (388.5 KB)
October 24, 2013 01:49AM
Perhaps just some teflon tape would have keep the old setup from leaking?
November 02, 2013 02:55AM
I tried but it didnt work ,,u can see white teflon tape in my last uploaded pic
Edited 1 time(s). Last edit at 11/02/2013 02:56AM by sach00.
November 21, 2013 08:18PM
Been working on my buda knock off. Came for 3mm and want to use 1.75.
Added the 3OD/2ID ptfe tube and that was not enough.... kept jamming. So I got some 3mm brass tube, It now works to my satisfaction using 3mm ptfe and 3mm brass inserts.
November 22, 2013 02:19AM
sach00
If the nozzle doesn't touch the heater block you will get a good seal in most cases. The tapered end of the threaded section should close tight on to the nozzle, but if the nozzle is touching the heater block it can't do that.
My design is very similar to the original that you have. The threaded section has a 118 degree taper and the nozzle has an internal taper of 118 degrees. When screwed together there is a perfect seal and no leakage.
[regpye.com.au]
"Experience is the mother of all knowledge." --Leonardo da Vinci
November 25, 2013 10:10PM
My chinese buda was leaking as well. I took it apart, burned off the excess plastic, and cleaned the threads with a 10mm die. wrapped the crud out of it with teflon tape and the leaking stopped.
Jeff.
