Solid layers aren't solid October 17, 2013 01:34PM |
Re: Solid layers aren't solid October 17, 2013 02:27PM |
Re: Solid layers aren't solid October 18, 2013 03:19AM |
Re: Solid layers aren't solid October 18, 2013 11:43AM |
Re: Solid layers aren't solid October 19, 2013 05:11PM |
Re: Solid layers aren't solid October 19, 2013 06:04PM |
Re: Solid layers aren't solid October 19, 2013 06:53PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Solid layers aren't solid October 21, 2013 01:24AM |
Re: Solid layers aren't solid November 25, 2013 12:06AM |
lister6520
You just need to increase the amount of material extruded in the solid layers, or the filament is being laid down too far apart..
In the print settings tab find the 'Infill' entry in the extrusion width box. If it is not zero reduce the number by perhaps 20% for a start and see how it goes. The smaller you make the number the closer the strands will be laid down in the solid infill, eliminating the gaps you are getting. You will need to do this by some trial and error. If you reduce it too much the printer will try to stuff too much material into a small space and make a mess, so you have to look for the optimum number.
If the number is zero then it is setting this automatically, and probably incorrectly. Try staring with 0.4, which is a bit more than the nozzle width. If there are still gaps decrease it. If there seems to be too much plastic being extruded then increase it.
Here I am assuming that only the solid infill is too thin. If even the side walls (perimeters) seem weak then perhaps you need to tweak the overall flow rate rather than just that of the solid layers.
To do this go to the filament settings, where I am assuming you have entered the measured diameter of 1.6mm in the 'Diameter' box. Just below it there is 'Extrusion multiplier' which is usually set to 1. Tweak this number, perhaps starting in steps of 10%. AFAIK increasing the number extrudes more material, decreasing the number extrudes less.
Re: Solid layers aren't solid November 25, 2013 08:49AM |
Re: Solid layers aren't solid November 25, 2013 12:14PM |
