Are direct drive extruders any good? November 02, 2013 08:47PM |
Re: Are direct drive extruders any good? November 02, 2013 09:24PM |
Re: Are direct drive extruders any good? November 02, 2013 09:44PM |
Re: Are direct drive extruders any good? November 02, 2013 09:53PM |
Re: Are direct drive extruders any good? November 02, 2013 09:56PM |
Re: Are direct drive extruders any good? November 02, 2013 10:19PM |
Re: Are direct drive extruders any good? November 03, 2013 01:52AM |
Re: Are direct drive extruders any good? November 03, 2013 07:51AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Are direct drive extruders any good? November 03, 2013 12:54PM |
Re: Are direct drive extruders any good? November 03, 2013 01:54PM |
Re: Are direct drive extruders any good? November 03, 2013 04:00PM |
nophead
NEMA stepper motors have 5mm ball bearings at each end so adding an external one is not going to make a massive difference. I have never noticed any play develop even on motors that have been used continuously for years.
1.75mm filament is about 3 times easier to push and the Wades gearing is about 3: 1 so you definitely don't want gears with 1.75mm.
Re: Are direct drive extruders any good? November 08, 2013 08:58AM |
Re: Are direct drive extruders any good? November 08, 2013 04:06PM |
Re: Are direct drive extruders any good? November 08, 2013 05:58PM |
Re: Are direct drive extruders any good? November 08, 2013 06:18PM |
Re: Are direct drive extruders any good? November 08, 2013 06:46PM |
Re: Are direct drive extruders any good? November 08, 2013 07:30PM |
Re: Are direct drive extruders any good? November 08, 2013 08:01PM |
Re: Are direct drive extruders any good? November 08, 2013 09:23PM |
Re: Are direct drive extruders any good? November 09, 2013 05:17AM |
Re: Are direct drive extruders any good? November 09, 2013 10:22AM |
Re: Are direct drive extruders any good? November 09, 2013 12:44PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Are direct drive extruders any good? November 09, 2013 01:15PM |
Re: Are direct drive extruders any good? November 09, 2013 03:21PM |
Re: Are direct drive extruders any good? November 09, 2013 06:24PM |
Re: Are direct drive extruders any good? November 09, 2013 06:59PM |
Re: Are direct drive extruders any good? November 09, 2013 07:08PM |
Re: Are direct drive extruders any good? December 08, 2013 06:15AM |
Re: Are direct drive extruders any good? July 18, 2015 12:52PM |
(Actual motor current / Rated motor current) * Motor holding torque * Extruder microsteps/mm = between 5500 and 9000
Re: Are direct drive extruders any good? July 19, 2015 03:58AM |
