First build teething problems: Z-axis out of sync December 13, 2013 07:14AM |
Re: First build teething problems: Z-axis out of sync December 13, 2013 02:33PM |
Re: First build teething problems: Z-axis out of sync December 14, 2013 03:04PM |
#define DEFAULT_MAX_FEEDRATE {500, 500, 2, 45}
#define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000}
#define DEFAULT_ACCELERATION 3000
#define DEFAULT_RETRACT_ACCELERATION 3000
#define DEFAULT_MAX_ACCELERATION {450,450,10,10000}
#define DEFAULT_ACCELERATION 450
#define DEFAULT_RETRACT_ACCELERATION 450
I managed to print my first few things.Not pretty as there is some blobbing but its now going through to completion. I printed a second hollow calibration cube, bridging not as nice as the one I did with the first settings but I'm sure it's just all down to tweaking and calibration which I will now go into with the printer.
just need to sus out this random clunk. |
Re: First build teething problems: Z-axis out of sync December 15, 2013 09:33AM |
Re: First build teething problems: Z-axis out of sync December 27, 2013 05:12PM |
Re: First build teething problems: Z-axis out of sync December 28, 2013 03:10PM |
Re: First build teething problems: Z-axis out of sync December 29, 2013 05:35PM |
Re: First build teething problems: Z-axis out of sync December 29, 2013 05:46PM |
Re: First build teething problems: Z-axis out of sync January 01, 2014 03:35PM |
NEMA 17 Stepper Motor Model 17HS19-1684S - Specifications
Frame size 42 x 42mm - NEMA 17
1.8 degree step angle
Length 47mm
Holding torque 44 N.cm (4.4kg.cm, 62oz.in)
Voltage 2.8V
Current/Phase 1.68A
Resistance/Phase 1.65ohm
Inductance/Phase 2.8mH
Inertia 68g.cm
Bipolar, 4-wire
Weight 0.35kg
Step Angle Accuracy ±5%(full step,no load)
Resistance Accuracy ±10%
Inductance Accuracy ±20%
Temperature Rise 80?Max.(rated current,2 phase on)
Ambient Temperature -10?-+50?
Insulation Resistance 100M?Min. 500VDC
Dielectric Strength 500VAC for one minute
Shaft Radial Play 0.02Max.(450 g-load)
Shaft Axial Play 0.08Max.(450 g-load)
Re: First build teething problems: Z-axis out of sync January 01, 2014 03:50PM |
