filaments entre tours
December 16, 2013 09:50AM
I make a flat piece with 4 vertical cylinders above. The problem is the filaments between the cylinders. The cylinders are bristling with pikes. The printer should print one cylinder and do the following after. Is it possible to program it with Repetier 0.84, thank you!
Edited 5 time(s). Last edit at 12/16/2013 10:16AM by pierre&johan.
Re: filaments entre cylindres
December 16, 2013 10:03AM
j'ai fais une pièce composée d'un socle plat et de 4 cylindres verticaux de 8 millimètres de diamètre dessus. Le problème : les filaments entre les cylindres.
Le logiciel est:repetier 0,84. L'imprimante devrait faire un cylindre à la fois. Est-ce possible de programmer ?
Merci de me conseiller !
P & J
December 16, 2013 10:36AM
Do you want to finish one cylinder and then proceed to the next cylinder (on the same layer) or do you want to print each cylinder in its own colour?
December 16, 2013 12:18PM
I want to finish a cylinder and make another on the same level
Edited 1 time(s). Last edit at 12/16/2013 12:23PM by pierre&johan.
December 16, 2013 12:22PM
Re: filaments entre tours
December 16, 2013 12:51PM
Bonjour et bienvenue!
Il y a un forum pour les utilisateurs francophone ici:
forum français
Without seeing photos, I would guess that the stringing between objects is insufficient anti-ooze retraction.
I know some software can print one object at a time, but I have not used that feature. Others with more experiance will have to answer that one!
Yvan
Singularity Machine
December 16, 2013 01:19PM
