z-axis moves up from home when printing December 20, 2013 04:35PM |
Re: z-axis moves up from home when printing December 20, 2013 11:04PM |
Re: z-axis moves up from home when printing December 20, 2013 11:31PM |
Re: z-axis moves up from home when printing December 20, 2013 11:34PM |
; generated by Slic3r 1.0.0RC1 on 2013-12-20 at 22:35:52 ; layer_height = 0.2 ; perimeters = 2 ; top_solid_layers = 4 ; bottom_solid_layers = 4 ; fill_density = 0.15 ; perimeter_speed = 30 ; infill_speed = 60 ; travel_speed = 130 ; nozzle_diameter = 0.4 ; filament_diameter = 1.75 ; extrusion_multiplier = 1 ; perimeters extrusion width = 0.40mm ; infill extrusion width = 0.67mm ; solid infill extrusion width = 0.67mm ; top infill extrusion width = 0.67mm ; first layer extrusion width = 0.30mm G21 ; set units to millimeters M107 M190 S70 ; wait for bed temperature to be reached M104 S235 ; set temperature G28 ; home all axes G1 Z5 F5000 ; lift nozzle M109 S235 ; wait for temperature to be reached G90 ; use absolute coordinates G92 E0 M82 ; use absolute distances for extrusion G1 F1800.000 E-1.00000 G92 E0 G1 Z0.150 F7800.000 G1 X47.120 Y47.120 F7800.000 G1 E1.00000 F1800.000
Re: z-axis moves up from home when printing December 21, 2013 01:29AM |
Re: z-axis moves up from home when printing December 21, 2013 10:17AM |
Re: z-axis moves up from home when printing December 21, 2013 11:22AM |
Re: z-axis moves up from home when printing December 21, 2013 12:14PM |
Re: z-axis moves up from home when printing December 21, 2013 12:30PM |
Re: z-axis moves up from home when printing December 21, 2013 05:52PM |
Re: z-axis moves up from home when printing December 21, 2013 07:07PM |
Re: z-axis moves up from home when printing December 21, 2013 09:53PM |
Re: z-axis moves up from home when printing December 21, 2013 10:22PM |
Re: z-axis moves up from home when printing December 21, 2013 10:28PM |
Re: z-axis moves up from home when printing December 22, 2013 03:03AM |
Re: z-axis moves up from home when printing December 22, 2013 03:08AM |
Re: z-axis moves up from home when printing December 22, 2013 12:56PM |
Re: z-axis moves up from home when printing December 22, 2013 03:02PM |
Re: z-axis moves up from home when printing December 22, 2013 04:23PM |
Re: z-axis moves up from home when printing December 23, 2013 01:34AM |
Re: z-axis moves up from home when printing December 23, 2013 09:44AM |
Re: z-axis moves up from home when printing December 24, 2013 11:58PM |
Re: z-axis moves up from home when printing December 25, 2013 12:05AM |
Re: z-axis moves up from home when printing December 25, 2013 12:12AM |
Re: z-axis moves up from home when printing December 25, 2013 01:45PM |
Re: z-axis moves up from home when printing December 25, 2013 01:48PM |
jb92563
I am also having that same problem with my ord bot Hadron.
it uses threaded rods on the Z so I know there is no slipping.
Im also using the latest slic3r version.
I'll check the gcode as well to see if it is commanding the z to come back down far enough at the perimeter printing.
Re: z-axis moves up from home when printing December 25, 2013 06:21PM |
Re: z-axis moves up from home when printing January 01, 2014 12:17PM |
Re: z-axis moves up from home when printing January 01, 2014 12:27PM |
Re: z-axis moves up from home when printing September 29, 2017 06:16AM |
