Extruder gears
Posted by printer_man58
Extruder gears
January 02, 2014 10:05AM
My extruder stopped working properly. Up until now I was able to use the extruder to print and do it from pronterface. Now when I try to hit the extrude button on pronterface the gears don't move. It is not a temperature issue because if I physically move the gear it extrudes. I am using a wades extruder with PLA plastic
Re: Extruder gears
January 02, 2014 10:32AM
Does the motor shaft turn? If so check the set screw on the small gear. If not check the motor wires. If it's still a problem swap the extruder to the X axis and see if it moves. If it does swap stepper controllers. If that's not it check the driver board connections.
Re: Extruder gears
January 02, 2014 01:29PM
Thank you i did that and my problem was resolved
Re: Extruder gears
January 02, 2014 03:19PM
If it was the set screws, you are far from the first one to run into the problem.....
Re: Extruder gears
January 02, 2014 07:58PM
I had something similar about a month ago.
The print would start OK, but after about 5 layers it would stop extruding.
The grub screw was loose on the extruder motor.
I guess perhaps as everything warmed up the plastic cog expanded and then it would start to slip. But it had me fooled for a while as I thought it was an problem with the stepper driver or the motor overheating
