Removing ABS print took flake of glass of the bed ! January 05, 2014 02:05AM |
Re: Renoving ABS print took flake of glass of the bed ! January 05, 2014 02:43AM |
Re: Renoving ABS print took flake of glass of the bed ! January 05, 2014 05:39AM |
Re: Renoving ABS print took flake of glass of the bed ! January 05, 2014 12:48PM |
Re: Renoving ABS print took flake of glass of the bed ! January 05, 2014 02:53PM |
Re: Renoving ABS print took flake of glass of the bed ! January 05, 2014 04:37PM |
Re: Renoving ABS print took flake of glass of the bed ! January 05, 2014 04:49PM |
Re: Removing ABS print took flake of glass of the bed ! January 05, 2014 05:44PM |
Re: Removing ABS print took flake of glass of the bed ! January 05, 2014 06:27PM |
Re: Renoving ABS print took flake of glass of the bed ! January 05, 2014 07:59PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Removing ABS print took flake of glass of the bed ! January 05, 2014 11:59PM |
Re: Removing ABS print took flake of glass of the bed ! January 06, 2014 12:51AM |
Re: Removing ABS print took flake of glass of the bed ! January 06, 2014 09:41AM |
Re: Removing ABS print took flake of glass of the bed ! January 06, 2014 04:06PM |
Re: Removing ABS print took flake of glass of the bed ! January 07, 2014 04:08PM |
Re: Removing ABS print took flake of glass of the bed ! January 07, 2014 05:19PM |
bytemedwb
So one trick I have used for this is to pause the print after the first layer. Then, using a brush brush ABS juice over the first layer.
You will end up really stuck to the glass. But when I have done this there has been no curling.
Re: Removing ABS print took flake of glass of the bed ! January 07, 2014 05:31PM |
What about steel or stainless steel ?Quote
The aluminium may warp with the heat, so that is tricky
Re: Removing ABS print took flake of glass of the bed ! January 08, 2014 01:14AM |
Re: Removing ABS print took flake of glass of the bed ! January 08, 2014 03:35AM |
Re: Removing ABS print took flake of glass of the bed ! January 09, 2014 01:21PM |
Re: Removing ABS print took flake of glass of the bed ! January 09, 2014 05:05PM |
Re: Removing ABS print took flake of glass of the bed ! January 09, 2014 05:20PM |
Re: Removing ABS print took flake of glass of the bed ! January 09, 2014 10:23PM |
Re: Removing ABS print took flake of glass of the bed ! January 09, 2014 11:01PM |
