Z homing issue after Marlin firmware update January 13, 2014 10:00PM |
Re: Z homing issue after Marlin firmware update January 14, 2014 09:08AM |
Re: Z homing issue after Marlin firmware update January 15, 2014 12:13PM |
Re: Z homing issue after Marlin firmware update January 15, 2014 04:09PM |
Re: Z homing issue after Marlin firmware update January 15, 2014 04:45PM |
Re: Z homing issue after Marlin firmware update January 16, 2014 04:29PM |
Re: Z homing issue after Marlin firmware update January 16, 2014 05:19PM |
Re: Z homing issue after Marlin firmware update May 26, 2014 08:53AM |
pcchameleon
I recently decided to update my Prusa i3 to the latest Marlin firmware (it was on Oct 2013 build). I made all the config changes in the configuration.h file for my old settings. Everything is working from what I can tell as it should except for when I home the Z axis. It just hummed until I turned the trimpot up to about 60% (which seems like way too much and motors hum loudly at idle now). If move the Z axis up and down in Pronterface (not homing), they travel just fine without any humming... It is confusing. The homing speed for the Z axis is set at 240 just like I had it before...I using a mechanical endstop at the Z min just like before...
I uploaded a video to help show the issue: [www.youtube.com]
Any ideas?
I know Marlin recently added Auto Bed Leveling into the code and I'm wondering if that is causing the issue but I made sure it is off in the configuration.h file.
Re: Z homing issue after Marlin firmware update June 13, 2015 06:16PM |
Re: Z homing issue after Marlin firmware update June 14, 2015 03:17AM |
Re: Z homing issue after Marlin firmware update June 14, 2015 04:21AM |
