E3D warping
Posted by Eric64124
E3D warping
February 11, 2014 02:58PM
Hi all,
I recently upgraded my i3 printer to an E3D v5 all metal hot end.
Since then I have problems with the first layer warping and detaching at the corners from the bed on larger objects.
I have a hunge that this is caused by the air flow from the cooling fan of the hot end blowing over my hot bed.
I am printing abs at 240 degrees, 110 degrees hot bed.
Has anybody got similar experience?
Thanks Eric
Re: E3D warping
February 11, 2014 03:23PM
Probably, thats why people with Magma hot ends run a fan with ducting to channel the air around the hot end but not on the part.
Re: E3D warping
February 12, 2014 02:12AM
After buying E3D i found out that supplied thermistor is showing whole 20C more than actual( checked with digital thermometer) if selected no 1 in marlin, number 6 is actually very close. So check actual temperature if you can or just print hotter and see if there is a difference.
Re: E3D warping
February 12, 2014 11:41AM
Eric64124
Hi all,
Thanks Eric
I've encountered similar situation with other hotends that needs active cooling. What I did was simply "kapton tape" a duct to prevent the air from directed towards the bed.
Re: E3D warping
February 12, 2014 12:58PM
Read this article, it includes a re-designed fan duct for the E3D to channel airflow away from the print. I just kapton taped a duct on mine since the duct from the link didn't fit right for me.
Re: E3D warping
February 16, 2014 06:56AM
sheck626
Thanks, printing that duct with a temporary duct out of kapton right now...
