Opto Endstop 2.1 Confusion
Posted by djspark
December 03, 2009 06:45PM
I may be a bit slow, but can someone translate this?
Insert the short leg (negative) into the hole closest to the flat side of the silkscreen.
which side is the flat side of the silkscreen? I'm not seeing a 'rounded' side. In the photo it appears as if the positive is on the left.
Thanks in advance :-)
Re: Opto Endstop 2.1 Confusion
December 03, 2009 06:54PM
if you read "Blocked", at the right side..
Wolfgang
December 03, 2009 07:03PM
Oh... I see now the circle is flat on top... wow I must be getting old, I didn't see that at first. So, to be absolutely sure... Negative is the top hole (assuming the board is placed with the text reading left to right)?
Thanks,
djspark
December 03, 2009 07:46PM
I believe you are trying to put an LED onto a circuit board.
A LED has a + and a - lead.
The silk screen image on the circuit board should have a D shape
where the LED goes. which should match the D shape of the LED's bottom so you put it in right.
alternatively there will be a "+" or a "-" on the board. Match the negative leg with the negative hole. etc
Hopefully this helps
regards
Stephen
December 03, 2009 07:59PM
Thank you very much Stephen, i never noticed that LED's were D shaped. And all the other boards I ever put them in had +'s & -'s.
Thanks everyone :-)
