Annoying z banding issue prusa i3, possible fix? February 16, 2014 12:44PM |
Re: Annoying z banding issue prusa i3, possible fix? February 16, 2014 01:05PM |
Re: Annoying z banding issue prusa i3, possible fix? February 16, 2014 02:39PM |
Re: Annoying z banding issue prusa i3, possible fix? February 16, 2014 02:56PM |
Re: Annoying z banding issue prusa i3, possible fix? February 19, 2014 07:15PM |
Re: Annoying z banding issue prusa i3, possible fix? February 19, 2014 07:42PM |
Re: Annoying z banding issue prusa i3, possible fix? February 20, 2014 01:08PM |
Re: Annoying z banding issue prusa i3, possible fix? February 21, 2014 08:58PM |
Re: Annoying z banding issue prusa i3, possible fix? February 21, 2014 10:46PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 12:04PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 12:10PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 12:47PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 12:55PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 01:10PM |
M500: stores paramters in EEPROM M501: reads parameters from EEPROM If you need to reset them after you changed them temporarily M502: reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to. M503: Print settings
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 06:10PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 06:55PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 09:38PM |
Re: Annoying z banding issue prusa i3, possible fix? February 22, 2014 09:44PM |
Re: Annoying z banding issue prusa i3, possible fix? February 23, 2014 12:55AM |
Re: Annoying z banding issue prusa i3, possible fix? February 23, 2014 10:09AM |
Re: Annoying z banding issue prusa i3, possible fix? February 23, 2014 10:45AM |
Re: Annoying z banding issue prusa i3, possible fix? February 23, 2014 10:50AM |
Re: Annoying z banding issue prusa i3, possible fix? February 23, 2014 11:35AM |
Horse Renoir
Hi all,
Heres the comparison pictures, They are both printed at 0.2mm layer heights
The one on the left is printed using Cura and the one on the right is printed using Repetier Host
[imagebin.org]
Re: Annoying z banding issue prusa i3, possible fix? February 23, 2014 02:45PM |
). Find a picture of a bolt, magnify it and look at it closely. What you will see is a triangular wave, with its crest and trough oscillating 180 deg as the bolt turns. This is the cause of banding.When using a collar to fit the rod to the motor over the screws, this issue becomes apparent. So my solution which seems to be working in early testing is to machine a hole using a bit the size of the motor shaft on a lathe. turning down the exterior, 3 set screws are installed to fasten the screw firmly to the motor shaft. The upper end is then turned down leaving a smooth surface to set close fit in a bearing. While I have yet to print anything, the Z motion seems to be quite smooth and even. Now I am using a rather heavy bolt (12mm I think - been a while) For a smaller bolt you could turn the first 5/8 inch or so of threads to exactly match the motor shaft diameter, and use a coupler.
Re: Annoying z banding issue prusa i3, possible fix? February 26, 2014 09:12AM |
Re: Annoying z banding issue prusa i3, possible fix? February 26, 2014 04:25PM |
Re: Annoying z banding issue prusa i3, possible fix? February 26, 2014 06:34PM |
Re: Annoying z banding issue prusa i3, possible fix? February 26, 2014 11:01PM |
Re: Annoying z banding issue prusa i3, possible fix? February 27, 2014 09:11AM |
Re: Annoying z banding issue prusa i3, possible fix? February 27, 2014 09:30AM |
