Re: I3 Omega from Diytechshop March 12, 2014 05:01AM |
Re: I3 Omega from Diytechshop March 12, 2014 09:31AM |
Re: I3 Omega from Diytechshop March 12, 2014 09:42AM |
Re: I3 Omega from Diytechshop March 12, 2014 10:52AM |
Re: I3 Omega from Diytechshop March 12, 2014 12:35PM |
Admin Registered: 17 years ago Posts: 1,472 |
Yes, for printing with PLA. Not necessary for ABS. This is just to keep the thermal break (PEEK) cool enough so that the PLA doesn't become rubbery too far up and cause too much friction to be pushed through.Quote
cfy7
I read somewhere that the inventor of the j head thinks his should be run with a fan.
I build my machines primarily with metric hardware, but also use standard (fractional inch) bits to clean up printed parts. Since drilling out holes is usually just to clear bolt threads, this works just fine. A slightly over-sized hole doesn't hurt anything, and in fact usually helps with assembly. Note that I haven't built one of DIYTechShop's machines though.Quote
cfy7
I used standard bits to clean up my parts. I don't have any metric as well.
Re: I3 Omega from Diytechshop March 12, 2014 01:50PM |
Re: I3 Omega from Diytechshop March 12, 2014 03:20PM |
Re: I3 Omega from Diytechshop March 12, 2014 03:30PM |
cfy7
I forgot to say, Diytechshop assured me their hotends are fixed, so it shouldn't be a problem. They seemed pretty confident of this and there haven't been any reports of the new ones failing on here.
I hope to have my E3D today. If it comes I'll post some pics of it attached.
Re: I3 Omega from Diytechshop March 13, 2014 01:36AM |
Re: I3 Omega from Diytechshop March 13, 2014 03:22PM |
Re: I3 Omega from Diytechshop March 13, 2014 03:37PM |
cfy7
Got my E3d today and only had about an hour to play with it. Yesterday I managed to print out a mounting plate from thingiverse to fit the e3d. Today I took an extruder body and drilled out a hole in the bottom big enough for the top of the e3d to recess into. It mounted up pretty well.
The thing is awesome! I was barely able to print at 10mm/s with my old failing hotend. I put the e3d at 50 mm/s and 220c and it printed so smoothly. I couldn't believe it. I can't wait to try going faster with it just to see if it can.
I still haven't received my replacement hotend from diytechshop so I can't say if the new ones are any better, but as it stands I'm not a fan of the old one.
Re: I3 Omega from Diytechshop March 14, 2014 02:54AM |
Re: I3 Omega from Diytechshop March 14, 2014 03:38AM |
Re: I3 Omega from Diytechshop March 14, 2014 10:14AM |
mrpaulie
It's been like 3 weeks since my I3A arrived and I have not been able to get it to move and finally I read this thread and I have to Jumper the pins under the stepper drivers? Holy crap, that's a huge step I missed. Do you have pictures of how that would look? I work during 100% of their support hours, so I haven't been able to get anything resembling help on this thing.
Re: I3 Omega from Diytechshop March 14, 2014 10:46AM |
Re: I3 Omega from Diytechshop March 14, 2014 03:30PM |
cfy7
Speaking of E3D, this thing is amazing. It is printing so much faster then my old hotend. At the moment it seems to like doing the perimeters a little slower, but it can fly on the infill. I'm very impressed. The design just makes sense on this thing. I'm printing with pla and it's working just fine.
My printer is at the local fedex office ready for pickup. I only have ABS so we'll see how it does with that, but I probably won't have the printer up and running for a few days. We have company coming and staying with us. I'll try and do the unboxing and check to see if everything is there.|
Re: I3 Omega from Diytechshop March 14, 2014 05:09PM |
Re: I3 Omega from Diytechshop March 15, 2014 03:48PM |
Re: I3 Omega from Diytechshop March 17, 2014 07:26PM |
Re: I3 Omega from Diytechshop March 17, 2014 08:39PM |
Re: I3 Omega from Diytechshop March 17, 2014 09:42PM |
cfy7
Should be 5 sets of motor wires. I shaved the plastic connectors on mine so that they could both fit on the ramps board for the z axis. Personally I didn't trim mine since I wanted to keep em long incase I ever take it apart and use the motors on a different machine.
I've seen they're using different motor wires and different connectors for their printers, so you could have a different setup. Mine came with the motors, and 5 sets of wires with a connector that fit the motor. They were all long enough to make it to the ramps with plenty of room to spare. The kit also came with 5 wire sets to go from the motor wires to thre ramps that were all at precut lengths. They had no use in my kit so I didn't use them. Also came with crimp on connectors for them that I didn't need. The last parts they came with were the pins and connectors to go to the ramps. I crimped and soldered them all.
cfy7
It's a shame they're not including wing nuts. I think it's much nicer with wing nuts. There are better ways to save money on kits.
cfy7
You could just throw some tape on the heat sinks. They actually sent me new heat sinks with the new drivers they sent me that they had already taped. I had hoped they started doing this to prevent future problems. Guess not. I bought some spare drivers on ebay that came with the perfect size heat sinks for under 20 bucks. They were in the US and took a couple days to arrive. It's good to have extra drivers since they get fried all too easily. I especially think they should have some tape on those heat sinks because they have a replacement policy in place that they'll replace those parts, even if it's your fault. (So it ends up costing them money, not you. Great policy by the way, and one of the main reasons I picked them to buy my machine from.)
I'm anxious to get started but have to finish some of my day job work first, lol.|
Re: I3 Omega from Diytechshop March 17, 2014 09:54PM |
Re: I3 Omega from Diytechshop March 17, 2014 10:07PM |
cfy7
Nothing fancy with the tape. Just use the double sided to stick em on the drivers, but throw some kapton on the edges of the heat sinks so that if they do slip they'll be insulated and can't short out.
Your motor wires are way different than mine, my motors only have 4 wires coming out in their wire bundles.
Re: I3 Omega from Diytechshop March 18, 2014 03:56AM |
brucehvn
I'm beginning to think I prefer soldering the wires instead of using the crimp joints. I guess I should decide soon which way to go
Re: I3 Omega from Diytechshop March 18, 2014 12:32PM |
Re: I3 Omega from Diytechshop March 18, 2014 09:56PM |
Re: I3 Omega from Diytechshop March 18, 2014 10:25PM |
Re: I3 Omega from Diytechshop March 18, 2014 10:41PM |
Re: I3 Omega from Diytechshop March 19, 2014 09:20PM |
Re: I3 Omega from Diytechshop March 19, 2014 09:27PM |
