MendelMax 2.0 Extruder problem
Posted by Norbert91
February 20, 2014 07:24AM
Hello Guys!
I am bulding right now a MendelMax 2.0. This will be my very first 3d printer. I stopped at the extruder, couse The original design uses Head Mk V-BV Hotend, but Its much easier (for me) to buy J-Head MK-V HotEnd. The maxstruder is compatible with it? What if I choose a complitly another extruder, e.g Greg's Wade extruder? Can I solve the assembly with the original parts? I've already cut out the aluminium parts, and got all the printed parts.
Thanks Guys
Re: MendelMax 2.0 Extruder problem
February 20, 2014 07:38AM
I'm also thinking on the all metal g3d hotend... That one is compatible with the design right?
Edited 1 time(s). Last edit at 02/20/2014 07:39AM by Norbert91.
February 20, 2014 06:55PM
The Maxstruder is a groovemount setup so all those will work. The two Jheads you mention are basically the same except the thermistor hole. The e3d needs a different lower filament guide available here: [www.dropbox.com]
The MendelMax 2 carriage should support a wades or gregs extruder.
Roy
Maker's Tool Works
