Pronterface / Slic3r Issue: Help!! February 21, 2014 03:34PM |
Re: Pronterface / Slic3r Issue: Help!! February 21, 2014 06:05PM |
Re: Pronterface / Slic3r Issue: Help!! February 23, 2014 09:01AM |
Re: Pronterface / Slic3r Issue: Help!! February 23, 2014 10:55AM |
Re: Pronterface / Slic3r Issue: Help!! February 23, 2014 04:34PM |
Re: Pronterface / Slic3r Issue: Help!! February 23, 2014 05:02PM |
Re: Pronterface / Slic3r Issue: Help!! February 24, 2014 10:41PM |
cat.farmer
if you look at your GCode in a text viewer do you see an
M104 S230 ; set temperature
command?
It should be near the top after all of the commented out ( settings.
Re: Pronterface / Slic3r Issue: Help!! February 24, 2014 10:43PM |
Re: Pronterface / Slic3r Issue: Help!! February 24, 2014 10:44PM |
Re: Pronterface / Slic3r Issue: Help!! March 01, 2014 02:24PM |
D-Wes
I usually preheat the bed and hot end manually from pronterface using the set controls in the lower left. If I don't the hot end will not heat up when the print begins. The appropriate commands are there in the gcode, but they don't seem to work unless the hot end is turned on manually. It took me a while to figure out that the default values are editable. You can also send temperature commands to the printer from the send box in the lower right corner. M104 S180 will set your hotend temperature to 180C
Re: Pronterface / Slic3r Issue: Help!! March 01, 2014 08:35PM |
Re: Pronterface / Slic3r Issue: Help!! March 01, 2014 08:37PM |
Re: Pronterface / Slic3r Issue: Help!! March 02, 2014 02:43PM |
Re: Pronterface Issue: Help!! May 21, 2015 05:53AM |
