FIXED - First Layer starts *below* Z-endstop height
Posted by bobtiki
February 22, 2014 10:18PM
I've just recently unpacked my printer after moving across the country, and I'm in the process of re-calibrating it. It's a Prusa Mendel built from a MakerGear kit from two years ago.
For the life of me, I cannot figure this one out: The prints now start *below* the level of the Z endstop, crashing the head, and blocking the filament feed until the feeder gear strips a gouge in the filament.
Any suggestions where I might look for a wrong setting would be most helpful!
I'm running Marlin v1.0.5 firmare on the printer, and Repetier-Host Mac 0.56 and Slic3r 0.9.9 to control the print.
One unique thing I should mention is that I'm running with home to a MAX endstop on the X-axis (instead of a MIN), so I do have:
#define min_software_endstops false
…(or else I could never move away from my MAX endstop). However, I know of no reason that once zero'd on the MIN Z-endstop that any command should be given to make it lower than that level.
Any ideas?
Thanks!
Mark
Edited 2 time(s). Last edit at 02/24/2014 12:59AM by bobtiki.
Re: First Layer starts *below* Z-endstop height
February 24, 2014 12:58AM
Think I figured it out.
After attempting to fix it with a Z-offset, and trying this several times, I noticed it seemed to vary in height, every time the print head would home and then raise up to 5mm at the start of the print. In addition, the 5mm Z-move didn't seem to be smooth, but much faster than a usual Z-move, and made a terrible almost-grinding noise.
I noticed that in the Slic3r configuration, after it homed, the command was:
G1 Z5 F5000
I wondered if the high feed rate (F5000) was what was causing the issue, and removed that from the Start G-code, so it would raise at the standard Z rate.
This seems to have done it — it actually raises exactly 5mm every time, instead of some random amount, and the height is now consistent and predictable, so I guess the motors or the control board (RAMPS 1.4) weren't able to handle that high speed. Hopefully this helps someone else, if they run into this!
MB
Edited 1 time(s). Last edit at 02/24/2014 12:59AM by bobtiki.
February 24, 2014 03:01AM
HA!
Really fixed this time, I swear.
F5000 is perfectly reasonable. All I had to do is turn up the pot a tiny bit on my Z stepper driver. Perhaps it got jostled during the move.
