Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 24, 2014 10:50PM |
Re: Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 24, 2014 11:19PM |
Admin Registered: 17 years ago Posts: 1,472 |
Re: Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 25, 2014 10:48AM |
Re: Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 25, 2014 02:34PM |
NewPerfection
Have you run PID auto tune? Are the nozzle and heater block insulated somehow?
Re: Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 26, 2014 09:15AM |
Janski
NewPerfection
I have ran auto tune for the Heater but not for the bed. What would be the command for auto tune heater bed that is connected to ramps 1.4 "D10" port?
I am also insulating the block.
Please advise
Janski
Re: Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 27, 2014 02:05PM |
ok B:69.09 @:128 ok B:69.17 @:128 ok B:69.23 @:128 ok B:69.33 @:128 ok B:69.47 @:128 ok B:69.61 @:128 PID Autotune failed! timeout
. Currently I am using a 16gauge wire. Attached is the snapshot of what it looks like.
Re: Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 27, 2014 02:45PM |
Re: Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 27, 2014 03:26PM |
NewPerfection
The picture makes your problem clear. Pads 2 and 3 need to be soldered together along with the black wire, assuming you are using a 12V power supply. If you are only soldering to one of those pads, the heated bed will draw much less current, and fail to heat properly.
and yes I am using a 12V power supply
Re: Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 27, 2014 03:42PM |
Re: Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 27, 2014 04:33PM |
Janski
So what you are saying is that I should solder Red wire to #2 and Black wire to # 3? Instead the pictured 1 and 2?
Please explain what you mean by "Sadler together". Not sure if I am understanding that partand yes I am using a 12V power supply
Sorry for newbie questions but appreciate your input
Janski
Re: Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 27, 2014 05:00PM |
Re: Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 27, 2014 05:23PM |
Re: Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 27, 2014 06:28PM |
Re: Ord Bot: Heating Bed unable to reach 110C. Please Help ! February 27, 2014 06:29PM |
