Marlin dual extruder set-up instrucrions? February 27, 2014 06:56PM |
Re: Marlin dual extruder set-up instrucrions? February 27, 2014 07:27PM |
Admin Registered: 17 years ago Posts: 1,472 |
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
// #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
// #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis
Re: Marlin dual extruder set-up instrucrions? February 27, 2014 08:49PM |
Re: Marlin dual extruder set-up instrucrions? February 27, 2014 10:10PM |
Re: Marlin dual extruder set-up instrucrions? February 27, 2014 10:21PM |
Re: Marlin dual extruder set-up instrucrions? February 27, 2014 11:11PM |
Re: Marlin dual extruder set-up instrucrions? SOLVED! February 28, 2014 09:21AM |
