SD not working with Megatronics V2.0 with SainSmart LCD March 10, 2014 04:11AM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 10, 2014 04:35AM |
TheTechnicalNoob
With the marlin firmware you have to enable SDSUPPORT in the configuration.
Then you format the sdcard for FAT16 format and put a file on it called auto0.g which is your sliced gcode and it should automatically run it.
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 10, 2014 05:16AM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 10, 2014 07:54AM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 10, 2014 05:38PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 10, 2014 06:11PM |
Admin Registered: 16 years ago Posts: 1,470 |
With the default Marlin, the SD card pin definition would point to the built-in SD card reader. You would have to reassign the pins to point to the external card reader. To do this, you would need to know which pins the external SD card reader (on the LCD display) is connected to on the Megatronics board. Then change the pin definition in pins.h to the pins the external card reader are attached to.Quote
razor103
I was afraid no one would have the answer to this question. I can usually find something on the web but this issue I could not find anything. It reall is too bad. I had great hope for this to work. I guess I can always purchase another SD board and wire that up the aux port or something so I can move the SD slot away from the the Megatronics board but it really is silly considering that is what the one on the LCD is suppose to be doing which is why I purchased the enhanced display for in the first place. I could have just bought the other much simplier display for a whole lot less. If anyone knows anything about how to get this to work I would very much appreaciate any input you can provide.
- Paul
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 10, 2014 06:20PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 10, 2014 06:49PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 10, 2014 07:15PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 11, 2014 07:41AM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 11, 2014 08:06AM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 17, 2014 08:19PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 21, 2014 09:31PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 22, 2014 09:21AM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD March 22, 2014 05:47PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 06, 2014 01:37PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 06, 2014 05:49PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 07, 2014 06:55PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 08, 2014 09:35PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 09, 2014 12:08AM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 09, 2014 04:36PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 09, 2014 05:01PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 09, 2014 06:13PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 09, 2014 08:13PM |
stonefisher
I'm thinking of getting this set for a rostock style delta 3d printer. Is there any reason why I shouldn't?
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 09, 2014 08:18PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 09, 2014 09:38PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 09, 2014 10:10PM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 10, 2014 06:49AM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 10, 2014 08:03AM |
Re: SD not working with Megatronics V2.0 with SainSmart LCD April 11, 2014 07:26AM |
stonefisher
I thought you were supposed to run prints off a card if you wanted a smooth print job without pauses.
