Problem with my Reprap PrusaMendel
Posted by Kasmen
April 02, 2014 11:58PM
Hi Guy,
I've built a 3D Printer Reprap PrusaMendel after loaded the software the motor keep running in one direction.
Could anyone can advice what have I miss out. Thanks.
Re: Problem with my Reprap PrusaMendel
April 03, 2014 03:43AM
Which motor?
_______________________________________
Waitaki 3D Printer
April 04, 2014 04:04AM
Not a lot to go on, you set the end stop,,post the config.h file assuming you using marlin.
April 04, 2014 04:24AM
Hi Waitaki,
Thanks for your response. Actually all the motors running one direction.
April 04, 2014 05:13AM
If your endstops are not configured correctly the motors can do that but are you saying the same happens with the extruder motor too?
Waitaki 3D Printer
April 09, 2014 03:42PM
I had the same problem bro, you should take a look at the config.h file, because some firmwares like Marlin do invert the logic of the endstops by default. If all of them are "true" in the config.h file, you should put them on false. After that, go to Pronterface, connect your printer, and when you have it online, while you keep any endstop pressed, you send the M119 command, which will send you back the endstops readings. Then, your motors should me moving on two directions smiling smiley
open | download - Captura de pantalla de 2014-04-09 16:27:29.png (199.7 KB)
