Solved(ish)- Firmware for Megatronics V3.0 ?
Posted by MrDoctorDIV
April 05, 2014 04:32PM
So I'm having problems with uploading firmware to my Megatronics board, mainly in the finding firmware for it department. How do you find firmware compatible with your board? I want Repetier, but they only support up to v2.0. When I upload it I just get feedback like "³¸8ü©¶³Â¹ÁaaHKL$&&r, ÂÂÁÁaA°HLL,äHLLà°HLL,ä°HLL,äXHLL$äHLL#" Except even that isn't right because the internet doesn't like those symbols. Safe to assume I'm using the wrong firmware/config? I configured through [www.repetier.com] I can mastermind what I can see and play with in my mind, but programming is where I seriously lack and need the greatest help and hand holding.
Edited 1 time(s). Last edit at 04/06/2014 10:18AM by MrDoctorDIV.
Re: Firmware for Megatronics V3.0 ?
April 05, 2014 08:11PM
Try setting the baud rate to 115,200 on both the firmware and your PC.....
April 06, 2014 10:17AM
I "solved" the problem. I was right in saying that Repetier doesn't support V3.0 yet. I uploaded Marlin firmware and it worked right off the bat.
