RCC
Heated Bed karked it!
April 11, 2014 12:04AM
Hi guys,
Need some help to troubleshoot my bed which has just stopped after countless prints being fine...
What should I check for? What order should I check it in?
The bed feels room temp- so I don't think its the thermistor which reads 26C.
There's a red led on next to the mosfet. Im using arduino mega 2560 and ramps 1.4, with the PCB (mk2 I think) heated bed, with an aluminium plate.
Any ideas?
Thanks guys-
Rcc
Edited 1 time(s). Last edit at 04/11/2014 12:05AM by RCC.
Re: Heated Bed karked it!
April 11, 2014 05:57AM
If the LED is lit, then I assume you can read around 12v between the D8 terminals? If so, check the voltage at the bed where the wires are soldered for a similar reading. If that's ok, disconnect the wires from D8 and check the resistance of the bed (meter probes to the wires you disconnected) - should be around 1.2 to 1.4v.
_______________________________________
Waitaki 3D Printer
April 11, 2014 07:31AM
Resistance is in ohms, not volts..... smiling smiley
April 11, 2014 08:16PM
Yeah, I am a twat!
Waitaki 3D Printer
