What is the maximum bowden tube length admissible? April 11, 2014 05:46AM |
Re: What is the maximum bowden tube length admissible? April 11, 2014 07:30AM |
Re: What is the maximum bowden tube length admissible? April 11, 2014 08:26AM |
Re: What is the maximum bowden tube length admissible? April 11, 2014 09:56AM |
Re: What is the maximum bowden tube length admissible? April 11, 2014 11:34AM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: What is the maximum bowden tube length admissible? April 11, 2014 06:30PM |
Re: What is the maximum bowden tube length admissible? April 14, 2014 06:49PM |
Re: What is the maximum bowden tube length admissible? April 15, 2014 09:28AM |
dewasa
For the hysteresis I don't know, but if you need more torque, there is always a solution.
Re: What is the maximum bowden tube length admissible? April 15, 2014 01:01PM |
Re: What is the maximum bowden tube length admissible? April 15, 2014 03:09PM |
What you mention is similar to what is done on wire feed welders when welding aluminum. shouldn't be super complicated and would be good solution for a LARGE printer.Quote
zelogik
Or put two stepper in serial with mk7 hobbed gear and a sort of clutch for one motor only... Yes over priced and over complicated ... need another solution
Re: What is the maximum bowden tube length admissible? April 15, 2014 03:31PM |
Re: What is the maximum bowden tube length admissible? April 16, 2014 04:15AM |
Re: What is the maximum bowden tube length admissible? April 16, 2014 05:58PM |
Re: What is the maximum bowden tube length admissible? May 06, 2014 12:47PM |
Re: What is the maximum bowden tube length admissible? October 02, 2014 04:07PM |
Re: What is the maximum bowden tube length admissible? October 02, 2014 07:03PM |
Re: What is the maximum bowden tube length admissible? October 03, 2014 01:35AM |
Re: What is the maximum bowden tube length admissible? October 03, 2014 03:37AM |
