groove or grooveless hot end April 18, 2014 01:28AM |
Re: groove or grooveless hot end April 18, 2014 02:11AM |
ekaggrat
Is this a correct design decision or have they made a change to make manufacturing more easy.
ekaggrat
In my experience that increases the pressure need to extrude a lot more!!..
Re: groove or grooveless hot end April 18, 2014 03:24AM |
First I've read that the force to push a filament through a Teflon sleeve takes more force than a SS barrel.
Can you share your experience, and thoughts of why this occurred.
Re: groove or grooveless hot end April 19, 2014 05:27AM |
Re: groove or grooveless hot end April 19, 2014 06:28PM |
Re: groove or grooveless hot end April 20, 2014 08:22PM |
Re: groove or grooveless hot end April 20, 2014 09:35PM |
Re: groove or grooveless hot end April 20, 2014 09:40PM |
ekaggrat
@RP Iron Man
the m4pipe with 1.75mm and m5 pipe with 3mm should work fine as the wall thickness of the barrel would be less and the heat transferred would be also low... I have build two of my own hotend using the barrel from the mk7 extruder and they work great ... i also tried making one with a sleeve in it and that failed badly that's why the question of the sleeve came up ... but it could be that i may have been wrong somewhere....
maybe Thejollygrimreaper has a better explanation for the sleeve.... also the ss barrel only works good if it is mirror polished .... i tried making the barrel myself but i failed badly as i didn't have access to polishing tools...
thanks for the clarification though...
Re: groove or grooveless hot end April 20, 2014 10:11PM |
ekaggrat
Re: groove or grooveless hot end April 20, 2014 10:21PM |
A2
@ekaggrat:
ekaggrat
Polishing a 3D printer hot end barrel with sand
[www.youtube.com]
Usually, smoothing a barrel very finely requires costly equipment (namely specific reamers). Now, I did it with very basic tools: use a concrete drill bit that is 0.5 to 1 mm smaller than the inner diameter and which protrudes from the other side of the barrel. Plunge the tip of the barrel and the drill bit into a pot of sand (the finer the better, but it will get fine anyway when it gets ground). Using high speed rotation, the grains of sand are fragmented and dragged up and into the barrel, polishing nicely the inside. It obviously takes longer with stainless steel than with brass, but it did the job pretty well for me
[www.tridimake.com]
Obviously this is a hack using sand to polish the bore of a SS hot end, the presenter is fairly knowledgeable so maybe it comes out good enough.
If you search you can find abrasives that are ideally suited for polishing SS, and you could use the same technique depicted in the video to feed the abrasive medium into the barrel.
Re: groove or grooveless hot end April 20, 2014 11:46PM |
Re: groove or grooveless hot end April 21, 2014 02:15AM |
Re: groove or grooveless hot end April 21, 2014 03:48AM |
Re: groove or grooveless hot end April 21, 2014 05:26AM |
Re: groove or grooveless hot end May 14, 2014 10:49PM |
Re: groove or grooveless hot end May 14, 2014 11:50PM |
Re: groove or grooveless hot end May 15, 2014 02:01AM |
Re: groove or grooveless hot end May 15, 2014 11:11AM |
Re: groove or grooveless hot end May 19, 2014 12:17PM |
I should spend more time here and share more, but the format is not really well suited, thanks for sharing/redirecting/helping|
Re: groove or grooveless hot end May 20, 2014 08:22AM |
Admin Registered: 14 years ago Posts: 1,063 |
RP Iron Man
@ekaggrat
If you read closely into my design of the Prometheus Hot End you would have found out that there is a reason why I don't have a "thermal break" (machined groove) in the 1-piece nozzle and I actually designed an alternative.
Since Prometheus is a hot end with adjustable "thermal zones", the "transition-zone" has a different position on the 1-piece SS nozzle depending on the user configuration of these "thermal zones". Consequently, my customizable design cannot have a machined "thermal break" at the "transition-zone". Instead I simply use M5 threaded rod for the 3mm version and M4 threaded rod for the 1.75mm version. The result is a relatively small area to transmit heat from the "melt-zone", through the "transition-zone", to the "cold-zone". My hot end only transmits a little more heat than the E3D with the machined "thermal break" so this is not an issue.
Designs are usually more refined than they seem at first sight
As for the PTFE lined hot ends (which Prometheus is NOT since it is all-metal): usually the PTFE insert on J heads does not go all the way into the nozzle, but only lines the "transition-zone". I have to agree that it seems undesireable to insulate the filament within the "melt-zone" as this would decrease the rate of heat conduction to the plastic entering the "melt-zone" and therefore decrease the top speed of the hot end... I know that the Aluhotend has this configuration, so maybe Thejollygrimreaper can tune in and help us understand his reasons for this design decision.
As I said before, designs are usually more refined than they seem at first glance, so I am sure that Thejollygrimreaper has a good reason for that decision
Re: groove or grooveless hot end May 20, 2014 11:50AM |
Re: groove or grooveless hot end September 13, 2014 11:26AM |
RP Iron Man
@ekaggrat
Re: groove or grooveless hot end July 14, 2015 09:41PM |
Re: groove or grooveless hot end July 15, 2015 06:16AM |
Re: groove or grooveless hot end July 15, 2015 05:34PM |
