In Marlin, is there a way to switch the auto-home order to home y then x? Default is x then y. I'd like to format the sub routine directly so that I can't accidently call it in the x/y order.
Reason:
I have built a custom H-bot using all v-slot and no linear rods. I have set up the endstop switches in a fixed position so that the wires to them are stationary. If the dynamic frame is in the orientation of "H", then the switches are in the top left (X min and y max). If the nozzle first homes left the will be no switch to hit.
