Thermistor and pull up reisitor April 25, 2014 02:52PM |
Re: Thermistor and pull up reisitor April 27, 2014 09:58PM |
Re: Thermistor and pull up reisitor April 28, 2014 12:31PM |
Re: Thermistor and pull up reisitor April 28, 2014 01:02PM |
Re: Thermistor and pull up reisitor April 28, 2014 11:23PM |
Re: Thermistor and pull up reisitor April 29, 2014 06:33AM |
maybe start your own post Z Corp conversion to reprap once you get started make sure to post some pictures for usQuote
Schultz
It's had a few challenges. The x and y axis use DC servos, but I found drives that use the encoder information and are driven by the step and direction from the Azteeg board. The Z axis uses four 4 amp steppers, which also required separate larger drives, also driven by the Azteeg. With such a large platen we had to use AC heaters for the bed, which are controlled by a separate heat controller. We're looking forward to getting it together, I think when we're done it will outperform our Airwolf printer we have.
Re: Thermistor and pull up reisitor April 29, 2014 10:25PM |
Re: Thermistor and pull up reisitor June 03, 2014 06:09PM |
Re: Thermistor and pull up reisitor June 03, 2014 09:42PM |
