Heat Bed shuts off power supply May 02, 2014 11:13AM |
Re: Heat Bed shuts off power supply May 02, 2014 02:03PM |
Re: Heat Bed shuts off power supply May 02, 2014 04:08PM |
Re: Heat Bed shuts off power supply May 02, 2014 05:12PM |
DaveX
Check the open circuit resistance of the bed. If it is greater than about 1 ohm or so, then the bed shouldn't be pulling more than 12A and maybe the power supply isn't up to spec. If it's less than 1 ohm, then it could be trying to pull more than 12V/(bed resistance) out of the power supply and overloading it to shutdown.
Re: Heat Bed shuts off power supply May 02, 2014 05:14PM |
Thijs
The power supply is propably not up to the job. The heated bed uses a lot of power. Usually more than twice of all the other electronics combined. The link in your post does not work for me, but the cheap Chinese PSU's more often than not underdeliver their specs.
Re: Heat Bed shuts off power supply May 02, 2014 08:24PM |
Re: Heat Bed shuts off power supply May 03, 2014 02:22AM |
kevbme
DaveX
Im getting 1.3
Re: Heat Bed shuts off power supply May 03, 2014 02:45AM |
Re: Heat Bed shuts off power supply May 03, 2014 01:48PM |
Re: Heat Bed shuts off power supply May 04, 2014 04:03PM |
