Huge X-Axis droop on delta printer May 03, 2014 03:43PM |
Re: Huge X-Axis droop on delta printer May 03, 2014 04:59PM |
Re: Huge X-Axis droop on delta printer May 03, 2014 06:39PM |
Re: Huge X-Axis droop on delta printer May 03, 2014 07:09PM |
CygnusX1985
Yes, I adjusted my stepper drivers with a multimeter, which other way do you recommend?
Maybe I should have mentioned, that my printer is fairly tall with almost 700mm build height. While the printhead is coming down from the home position I can see how it slowly moves in the +x direction. If there are really lost steps involved, how can that effect only one axis on a delta printer ....
