Hi everybody, I am new here and I am in the process of building my first Reprap
So far so good, all my electronic is tested and working, I am waiting for parts to finish the mecanical side.
I have just one question:
I bought these thermistor for my hotbed: [
www.ebay.ca]
I am not sure which thermistor to chose in Marlin? (See farther below for thermistor specifications)
Thank's
Choices in Marlin:
//=============================Thermal Settings ============================
//--NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
//// Temperature sensor settings:
// -2 is thermocouple with MAX6675 (only for sensor 0)
// -1 is thermocouple with AD595
// 0 is not used
// 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
// 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
// 3 is mendel-parts thermistor (4.7k pullup)
// 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
// 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan) (4.7k pullup)
// 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
// 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
// 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
// 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
// 10 is 100k RS thermistor 198-961 (4.7k pullup)
// 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k
// (but gives greater accuracy and more stable PID)
// 51 is 100k thermistor - EPCOS (1k pullup)
// 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
// 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan) (1k pullup)
THERMISTOR SPECIFICATIONS
R25℃
100KΩ±1%
B Value(R25/50℃)
3990K 1%
Dissipation Factor(mW/℃)
1.1~1.6 In still Air
Thermal Time Constant(S)
10~17 In Still Air
Operating temperature range
(-50~+260°C)
Dimension
2.0mm Dia X4.1mm
Lead Length
32mm
